__Vectors DCD __initial_sp ; Top of Stack
DCD Reset_Handler ; Reset Handler
DCD NMI_Handler ; NMI Handler
DCD HardFault_Handler ; Hard Fault Handler
DCD MemManage_Handler ; MPU Fault Handler
DCD BusFault_Handler ; Bus Fault Handler
DCD UsageFault_Handler ; Usage Fault Handler
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD 0 ; Reserved
DCD SVC_Handler ; SVCall Handler
DCD DebugMon_Handler ; Debug Monitor Handler
DCD 0 ; Reserved
DCD OS_CPU_PendSVHandler ; PendSV Handler
DCD OS_CPU_SysTickHandler ; SysTick Handler
* OS_CPU_SysTickHandler()
* Description: Handle the system tick (SysTick) interrupt, which is used to generate the uC/OS-II tick
* interrupt.
* Arguments : none.
* Note(s) : 1) This function MUST be placed on entry 15 of the Cortex-M3 vector table.
void OS_CPU_SysTickHandler (void)
OS_CPU_SR cpu_sr;
OS_ENTER_CRITICAL(); /* Tell uC/OS-II that we are starting an ISR */
OSIntNesting++;
OS_EXIT_CRITICAL();
OSTimeTick(); /* Call uC/OS-II's OSTimeTick() */
OSIntExit(); /* Tell uC/OS-II that we are leaving the ISR */
在函数OSTimeTick()中
void OSTimeTick (void)
OS_TCB *ptcb;
#if OS_TICK_STEP_EN > 0
BOOLEAN step;
#endif
#if OS_CRITICAL_METHOD == 3 /* Allocate storage for CPU status register */
OS_CPU_SR cpu_sr = 0;
#endif
#if OS_TIME_TICK_HOOK_EN > 0
OSTimeTickHook(); /* Call user definable hook */
#endif
#if OS_TIME_GET_SET_EN > 0
OS_ENTER_CRITICAL(); /* Update the 32-bit tick counter */
OSTime++;
OS_EXIT_CRITICAL();
#endif
if (OSRunning == OS_TRUE) {
ptcb = OSTCBList; /* Point at first TCB in TCB list */
while (ptcb->OSTCBPrio != OS_TASK_IDLE_PRIO) { /* Go through all TCBs in TCB list */
if (ptcb->OSTCBDly != 0) { /* No, Delayed or waiting for event with TO */
if (--ptcb->OSTCBDly == 0) { /* Decrement nbr of ticks to end of delay */
/* Check for timeout */
if ((ptcb->OSTCBStat & OS_STAT_PEND_ANY) != OS_STAT_RDY) {
ptcb->OSTCBStat &= ~(INT8U)OS_STAT_PEND_ANY; /* Yes, Clear status flag */
ptcb->OSTCBStatPend = OS_STAT_PEND_TO; /* Indicate PEND timeout */
} else {
ptcb->OSTCBStatPend = OS_STAT_PEND_OK;
if ((ptcb->OSTCBStat & OS_STAT_SUSPEND) == OS_STAT_RDY) { /* Is task suspended? */
OSRdyGrp |= ptcb->OSTCBBitY; /* No, Make ready */
OSRdyTbl[ptcb->OSTCBY] |= ptcb->OSTCBBitX;
ptcb = ptcb->OSTCBNext; /* Point at next TCB in TCB list */
OS_EXIT_CRITICAL();
上面的函数中主要做了俩件事情:
1:给计数器OSTime加1操作。
2:遍历任务TCB链表中的所有TCB,在任务的OSTCBDly不为0时,对OSTCBDly减1操作,当OSTCBDly为0并且此TCB没有挂起,
则使此任务进入就绪状态。
