/* Enable PLL */
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) {
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x08)
/******************************************************************************* * Function Name : NVIC_Configuration
* Description : Configures Vector Table base location.
* Input : None
* Output : None
* Return : None
*******************************************************************************/ void NVIC_Configuration(void)
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
/******************************************************************************* * Function name : Fill_Buffer
* Description : Fill the global buffer
* Input : - pBuffer: pointer on the Buffer to fill
* - BufferSize: size of the buffer to fill
* - Offset: first value to fill on the Buffer
* Output param : None
*******************************************************************************/ void Fill_Buffer(u16 *pBuffer, u16 BufferLenght, u32 Offset)
u16 IndexTmp = 0;
/* Put in global buffer same values */
for (IndexTmp = 0; IndexTmp < BufferLenght; IndexTmp++ )
pBuffer[IndexTmp] = IndexTmp + Offset;
#ifdef DEBUG
/******************************************************************************* * Function Name : assert_failed
* Description : Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* Input : - file: pointer to the source file name
* - line: assert_param error line source number
* Output : None
* Return : None
*******************************************************************************/ void assert_failed(u8* file, u32 line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */ /* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
