/* It is possible that an ISR caused a task to be removed from an event
list while the scheduler was suspended. If this was the case then the
removed task will have been added to the xPendingReadyList. Once the
scheduler has been resumed it is safe to move all the pending ready
tasks from this list into their appropriate ready list. */
portENTER_CRITICAL();
{//将计数减一
--uxSchedulerSuspended;
//如果等于0,则允许调度
if( uxSchedulerSuspended == ( unsigned portBASE_TYPE ) pdFALSE )
if( uxCurrentNumberOfTasks > ( unsigned portBASE_TYPE ) 0 )
portBASE_TYPE xYieldRequired = pdFALSE;
/* As we have processed some ticks it is appropriate to yield
to ensure the highest priority task that is ready to run is
the task actually running. */
#if configUSE_PREEMPTION == 1
xYieldRequired = pdTRUE;
#endif
taskENTER_CRITICAL();
/* Ensure a yield is performed if the current task is being
suspended. */
if( pxTaskToSuspend == pxCurrentTCB )
pxTaskToSuspend = NULL;
