linux下X86架构IDT解析(3)
yuyang911220
2015-7-30 18:57
linux下X86架构IDT解析(3)
void
__init
trap_init
(void){
726
int
i
736
set_intr_gate
(X86_TRAP_DE, &
divide_error
737
set_intr_gate_ist
(X86_TRAP_NMI, &
nmi
NMI_STACK
739
set_system_intr_gate
(X86_TRAP_OF, &
overflow
740
set_intr_gate
(X86_TRAP_BR, &
bounds
741
set_intr_gate
(X86_TRAP_UD, &
invalid_op
742
set_intr_gate
(X86_TRAP_NM, &
device_not_available
743
#ifdef CONFIG_X86_32
744
set_task_gate
(X86_TRAP_DF,
GDT_ENTRY_DOUBLEFAULT_TSS
745
#else
746
set_intr_gate_ist
(X86_TRAP_DF, &
double_fault
DOUBLEFAULT_STACK
747
#endif
748
set_intr_gate
(X86_TRAP_OLD_MF, &
coprocessor_segment_overrun
749
set_intr_gate
(X86_TRAP_TS, &
invalid_TSS
750
set_intr_gate
(X86_TRAP_NP, &
segment_not_present
751
set_intr_gate_ist
(X86_TRAP_SS, &
stack_segment
STACKFAULT_STACK
752
set_intr_gate
(X86_TRAP_GP, &
general_protection
753
set_intr_gate
(X86_TRAP_SPURIOUS, &
spurious_interrupt_bug
754
set_intr_gate
(X86_TRAP_MF, &
coprocessor_error
755
set_intr_gate
(X86_TRAP_AC, &
alignment_check
759
set_intr_gate
(X86_TRAP_XF, &
simd_coprocessor_error
760
761
/* Reserve all the builtin and the syscall vector: */
762
for (
i
= 0;
i
FIRST_EXTERNAL_VECTOR
i
763
set_bit
i
used_vectors
764
765
#ifdef CONFIG_IA32_EMULATION
766
IA32_SYSCALL_VECTOR
ia32_syscall
767
set_bit
IA32_SYSCALL_VECTOR
used_vectors
768
#endif
