点击查看大图此前置补偿器模块可以说明PA非线性的主要部分。如果忽略此模块的记忆性,就可以看作Hammerstein模型的无记忆非线性部分。有了记忆以后,可以用作基于记忆多项式的前置补偿器。将各项重新排列,得到式C的关系。
对各项如此重新整理就将公式简化到了有限脉冲响应(FIR)的形式,就可能以对硬件有效的LUT形式实现|x(n-i)|2多项式。多项式的方次受到自适应算法模型精度容差的限制。
对某些类型的射频PA,额外的记忆效应依赖于信号包络线。例如,这些记忆效应可以源自多种不同因素,如热和行为接近功率曲线的函数的多倍增益的电源瞬变。式1中Volterra数列的项涉及到要放大的信号与复数信号包络的向量积,可以用于构成在探索RFPA的记忆效应及如何用滤波器改进线性方面有用的关系。
作者:Hardik Gandhi
相关阅读
参考文献
1.R. Sperlich, Y. Park, G. Copeland, and S. Kenney: “Power AmplifierLinearization with Digital Pre- Distortion and Crest Factor Reduction,”Proceedings of the 2004 IEEE Microwave Theory & TechniquesSymposium, pp. 669-672.
2. J. Kim and K. Konstantinou, “DigitalPredistortion of Wideband Signals Based on Power Amplifier Model withMemory,” Electronic Letters, vol. 37, No. 23, 2001, pp. 1417-1418.
3.T. Panicker and V. Mathews, “Parallel-Cascade Realizations andApproximations of Truncated Volterra Systems,” IEEE Transactions onSignal Processing, vol. 46, No. 10, 1998, pp. 2829-2832.
4. D.Morgan. Z. Ma, J. Kim, M. Zierdt, and J. Pastalan, “A generalizedmemory polynomial model for digital predistortion of RF poweramplifiers,” IEEE Transactions on Signal Processing, vol. 54, No. 10,2006, pp. 3852-3860.
5. A. Jhu and T. Brazil, “An adaptiveVolterra predistorter for linearization of RF high power amplifiers,”Proceedings of the 2002 IEEE Microwave Theory & TechniquesSymposium, pp. 461-46?.
6. P. Gilabert, G. Montoro, and E.Bertran, “On the Wiener and Hammerstein Models for Power AmplifierPredistortion,” Proceedings of the 2005 IEEE APMC.
7. A. Shahand B. Jalali, “Adaptive equalization for broadband predistortionlinearization of optical transmitters,” IEEE Proceedings onOptoelectronics, vol. 152, No. 1, 2005, pp. 16-32.
