基于HTTP在互联网传输敏感数据的消息摘要、签名与加密方案(2)
yuyang911220
2016-8-18 16:27
2.数字签名工具类:
Java代码 [url=]
[/url]
import java.security.MessageDigest;
import java.security.NoSuchAlgorithmException;
import java.util.ArrayList;
import java.util.Collections;
import java.util.List;
import org.apache.commons.lang.StringUtils;
import org.apache.log4j.Logger;
* @author lixuanbin
* @creation 2013-1-30
public
class SignatureUtil {
protected
static Logger log = Logger.getLogger(SignatureUtil.class);
private
static
final
char[] hexArray = "0123456789ABCDEF".toCharArray();
private String encryptionAlgorithm = "SHA-1";
public String bytesToHexString(byte[] bytes) {
char[] hexChars = new
char[bytes.length * 2];
for (int j = 0; j < bytes.length; j++) {
int v = bytes[j] & 0xFF;
hexChars[j * 2] = hexArray[v >>> 4];
hexChars[j * 2 + 1] = hexArray[v & 0x0F];
return
new String(hexChars);
public
byte[] hexStringToBytes(String s) {
int len = s.length();
byte[] data = new
byte[len / 2];
for (int i = 0; i < len; i += 2) {
data[i / 2] = (byte) ((Character.digit(s.charAt(i), 16) << 4) + Character
.digit(s.charAt(i + 1), 16));
return data;
* 使用指定算法生成消息摘要,默认是md5
* @param strSrc
* , a string will be encrypted; <br/>
* @param encName
* , the algorithm name will be used, dafault to "MD5"; <br/>
* @return
public String digest(String strSrc, String encName) {
MessageDigest md = null;
String strDes = null;
byte[] bt = strSrc.getBytes();
try {
if (encName == null || encName.equals("")) {
encName = "MD5";
md = MessageDigest.getInstance(encName);
md.update(bt);
strDes = bytesToHexString(md.digest()); // to HexString
} catch (NoSuchAlgorithmException e) {
log.error("Invalid algorithm: " + encName);
return
null;
return strDes;
* 根据appid、token、lol以及时间戳来生成签名
* @param appid
* @param token
* @param lol
* @param millis
* @return
public String generateSignature(String appid, String token, String lol,
long millis) {
String timestamp = String.valueOf(millis);
String signature = null;
if (StringUtils.isNotBlank(token) && StringUtils.isNotBlank(timestamp)
&& StringUtils.isNotBlank(appid)) {
List<String> srcList = new ArrayList<String>();
srcList.add(timestamp);
srcList.add(appid);
srcList.add(token);
srcList.add(lol);
// 按照字典序逆序拼接参数
Collections.sort(srcList);
Collections.reverse(srcList);
StringBuilder sb = new StringBuilder();
for (int i = 0; i < srcList.size(); i++) {
sb.append(srcList.get(i));
signature = digest(sb.toString(), encryptionAlgorithm);
srcList.clear();
srcList = null;
return signature;
* 验证签名: <br/>
* 1.根据appid获取该渠道的token;<br/>
* 2.根据appid、token、lol以及时间戳计算一次签名;<br/>
* 3.比较传过来的签名以及计算出的签名是否一致;
* @param signature
* @param appid
* @param lol
* @param millis
* @return
public
boolean isValid(String signature, String appid, String lol,
long millis) {
String token = findTokenById(appid);
String calculatedSignature = generateSignature(appid, token, lol,
millis);
log.info("calculated signature: \n" + calculatedSignature);
if (StringUtils.equals(calculatedSignature, signature)) {
return
true;
} else {
return
false;
* FIXME For demo only, should be a different string in production.
* @param appid
* @return
public String findTokenById(String appid) {
String token = "#@!1234567890!@#";
return token;
public
static
void main(String[] args) {
SignatureUtil generator = new SignatureUtil();
String xmlString = "<root><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name><name>test</name></root>";
System.out.println(xmlString.getBytes().length);
String digest = generator.digest(xmlString, "MD5");
System.out.println(digest);
System.out.println(digest.getBytes().length);
String appid = "canairport001";
String token = generator.findTokenById(appid);
long millis = System.currentTimeMillis();
String signature = generator.generateSignature(appid, token, digest,
millis);
System.out.println(signature);
boolean isValid = generator.isValid(signature, appid, digest, millis);
System.out.println(isValid);
3.发送方代码:
Java代码 [url=]
[/url]
import java.io.IOException;
import java.util.HashMap;
import java.util.Iterator;
import java.util.Map;
import java.util.Map.Entry;
import org.apache.http.HttpEntity;
import org.apache.http.HttpHost;
import org.apache.http.HttpResponse;
import org.apache.http.HttpStatus;
import org.apache.http.auth.AuthScope;
import org.apache.http.auth.UsernamePasswordCredentials;
import org.apache.http.client.ClientProtocolException;
import org.apache.http.client.methods.HttpPost;
import org.apache.http.conn.params.ConnRoutePNames;
import org.apache.http.entity.StringEntity;
import org.apache.http.impl.client.DefaultHttpClient;
import org.apache.http.message.BasicHeader;
import org.apache.http.protocol.HTTP;
import org.apache.http.util.EntityUtils;
* @author ben
* @creation 2014年6月9日
public
class HttpclientUtil {
protected
static
final Logger log = Logger.getLogger(HttpclientUtil.class);
* 根据传入的uri和参数map拼接成实际uri
* @param uri
* @param paraMap
* @return
public String buildUri(String uri, Map<String, String> paraMap) {
uri = StringUtils.trim(uri);
uri = StringUtils.removeEnd(uri, "/");
uri = StringUtils.removeEnd(uri, "?");
sb.append(uri);
if (paraMap != null && !paraMap.isEmpty()) {
sb.append("?");
Iterator<Entry<String, String>> iterator = paraMap.entrySet()
.iterator();
while (iterator.hasNext()) {
Map.Entry<String, String> pair = iterator.next();
try {
String keyString = pair.getKey();
String valueString = pair.getValue();
sb.append(keyString);
sb.append("=");
sb.append(valueString);
sb.append("&");
} catch (Exception e) {
log.error(e, e);
return StringUtils.removeEnd(sb.toString(), "&");
