标题: 一则简单的Windows共享内存IPC代码 [打印本页]
作者: yuyang911220    时间: 2017-1-25 19:52     标题: 一则简单的Windows共享内存IPC代码
Windows共享内存可以让两个进程对同一块内存进行读写。
以下有2个进程,a.cpp生成A进程,b.cpp生成b进程。那么a进程将不停地读名为"Global\\MyFileMappingObject"的共享内存块,而b进程不停地写名为"Global\\MyFileMappingObject"的共享内存块。从而实现IPC。
复制代码
//a.cpp
#include <windows.h>
#include <string.h>
#include <string>
#include <iostream>
#include <tchar.h>
using namespace std;
#define BUF_SIZE 256
TCHAR szName[]=TEXT("Global\\MyFileMappingObject");    //指向同一块共享内存的名字
int main(int argc, char *argv[])
    HANDLE hMapFile;
    LPCTSTR pBuf;
    hMapFile = CreateFileMapping(
        INVALID_HANDLE_VALUE,    // use paging file
        NULL,                    // default security
        PAGE_READWRITE,          // read/write access
        0,                       // maximum object size (high-order DWORD)
        BUF_SIZE,                // maximum object size (low-order DWORD)
        szName);                 // name of mapping object
    if (hMapFile == NULL)
        _tprintf(TEXT("Could not create file mapping object (%d).\n"),
            GetLastError());
        return 1;
    pBuf = (LPTSTR) MapViewOfFile(hMapFile,   // handle to map object
        FILE_MAP_ALL_ACCESS, // read/write permission
        0,
        0,
        BUF_SIZE);
    if (pBuf == NULL)
        _tprintf(TEXT("Could not map view of file (%d).\n"),
            GetLastError());
        CloseHandle(hMapFile);
        return 1;
    //从main开始至此,A B process代码一样,都是获取名为"Global\\MyFileMappingObject"的共享内存的指针
    //以下代码,A不停地读共享内存pBuf
    while(1)
        cout<<pBuf<<endl;
        cout<<"A process: hit keyboard to receive from B process"<<endl;
        getchar();
    UnmapViewOfFile(pBuf);
    return 0;
复制代码
复制代码
//b.cpp
#include <iostream>
#include <Windows.h>
#include <tchar.h>
int main()
    HANDLE hMapFile;
    LPCTSTR pBuf;
            GetLastError());
        return 1;
        0,
        0,
        BUF_SIZE);
    if (pBuf == NULL)
            GetLastError());
        return 1;
    //以下代码,B不停写共享内存pBuf
    while(1)
        TCHAR s[BUF_SIZE];
        cout<<"B process: plz input sth. to be transfered to A process."<<endl;
        cin>>s;
        memcpy((PVOID)pBuf, s, BUF_SIZE);
