标题: linux程序运行分析 [打印本页]
作者: yuyang911220    时间: 2017-2-24 11:05     标题: linux程序运行分析
试验环境:
[jackie@cluster3 cLearn]$ gcc -v
Reading specs from /usr/lib/gcc/i386-RedHat-linux/3.4.6/specs
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --disable-checking --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-java-awt=gtk --host=i386-redhat-linux
Thread model: posix
gcc version 3.4.6 20060404 (Red Hat 3.4.6-3)
[jackie@cluster3 cLearn]$ uname -a
Linux cluster3 2.6.20 #11 SMP Tue Feb 13 20:53:01 CST 2007 i686 i686 i386 GNU/Linux
函数调用分析
1. 编写测试程序
#include <stdlib.h>
int foo(int fi,int fj)
        int fk;
        fk = 3;
        return 0;
int main()
        int mi;
        int mj;
        mi=1;
        mj=2;
        foo(mi,mj);
        return 0;
2.编译代码
gcc -g -o cc cc.c
3.用gdb进行debug:gdb cc
(gdb) list
4       {
5               int fk;
6               fk = 3;
7               return 0;
8       }
9       int main()
10      {
11              int mi;
12              int mj;
13              mi=1;
(gdb)
14              mj=2;
15              foo(mi,mj);
16              return 0;
17      }
(2)查看汇编代码:
(gdb) disass main
Dump of assembler code for function main:
0x08048348 <main+0>:    push   %ebp
0x08048349 <main+1>:    mov    %esp,%ebp
0x0804834b <main+3>:    sub    $0x8,%esp
0x0804834e <main+6>:    and    $0xfffffff0,%esp
0x08048351 <main+9>:    mov    $0x0,%eax
0x08048356 <main+14>:   add    $0xf,%eax
0x08048359 <main+17>:   add    $0xf,%eax
0x0804835c <main+20>:   shr    $0x4,%eax
0x0804835f <main+23>:   shl    $0x4,%eax
0x08048362 <main+26>:   sub    %eax,%esp
0x08048364 <main+28>:   movl   $0x1,0xfffffffc(%ebp)
0x0804836b <main+35>:   movl   $0x2,0xfffffff8(%ebp)
0x08048372 <main+42>:   pushl  0xfffffff8(%ebp)
0x08048375 <main+45>:   pushl  0xfffffffc(%ebp)
0x08048378 <main+48>:   call   0x8048334 <foo>
0x0804837d <main+53>:   add    $0x8,%esp
0x08048380 <main+56>:   mov    $0x0,%eax
0x08048385 <main+61>:   leave
0x08048386 <main+62>:   ret
End of assembler dump.
(gdb) disass foo
Dump of assembler code for function foo:
0x08048334 <foo+0>:     push   %ebp
0x08048335 <foo+1>:     mov    %esp,%ebp
0x08048337 <foo+3>:     sub    $0x4,%esp
0x0804833a <foo+6>:     movl   $0x3,0xfffffffc(%ebp)
0x08048341 <foo+13>:    mov    $0x0,%eax
0x08048346 <foo+18>:    leave
0x08048347 <foo+19>:    ret
(3)在主函数设置断点,并执行程序,让程序在main函数刚开始时暂停:
(gdb) break 9
Breakpoint 1 at 0x8048348: file cc.c, line 9.
(gdb) run
Starting program: /home/jackie/SourceDIR/cLearn/cc
Reading symbols from shared object read from target memory...done.
Loaded system supplied DSO at 0xb7f44000
Breakpoint 1, main () at cc.c:10
10      {
(4)查看关键寄存器内容:
(gdb) i reg esp
esp            0xbffbb77c       0xbffbb77c
(gdb) i reg ebp
ebp            0xbffbb7d8       0xbffbb7d8
(gdb) i reg eip
eip            0x8048348        0x8048348
可以看到当前eip的内容是0x8048348,要执行的指令是push   %ebp
