panfeng@ubuntu:~/segfault$ gdb ./segfault3
GNU gdb (GDB) 7.0-ubuntu
Copyright (C) 2009 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "i486-linux-gnu".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /home/panfeng/segfault/segfault3...done.
(gdb)
3、进入gdb后,运行程序:
[url=]复制代码[/url] 代码如下:
(gdb) run
Starting program: /home/panfeng/segfault/segfault3
Program received signal SIGSEGV, Segmentation fault.
0x001a306a in memcpy () from /lib/tls/i686/cmov/libc.so.6
(gdb)
panfeng@ubuntu:~/segfault$ gdb ./segfault3 ./core
warning: Can't read pathname for load map: 输入/输出错误.
Reading symbols from /lib/tls/i686/cmov/libc.so.6...(no debugging symbols found)...done.
Loaded symbols for /lib/tls/i686/cmov/libc.so.6
Reading symbols from /lib/ld-linux.so.2...(no debugging symbols found)...done.
Loaded symbols for /lib/ld-linux.so.2
Core was generated by `./segfault3'.
Program terminated with signal 11, Segmentation fault.
#0 0x0018506a in memcpy () from /lib/tls/i686/cmov/libc.6
