#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd G:/Graduation/Debug/LCD/software/lcd_test2/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="G:/Graduation/Debug/LCD/lcd_test
.sof" --output="lcd_test.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=lcd_te
st.opt G:/Graduation/Debug/LCD/lcd_test.sof lcd_test.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Allocated 54 megabytes of memory during processing
Info: Processing ended: Thu Jul 05 23:13:05 2007
Info: Elapsed time: 00:00:07
Info: Command: quartus_cpf --no_banner --convert lcd_test.pof lcd_test.rpd
Info: Allocated 51 megabytes of memory during processing
Info: Processing ended: Thu Jul 05 23:13:11 2007
Info: Elapsed time: 00:00:06
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00002000 --sidp=0x0
0000808 --id=2135972589 --timestamp=1183647553 "lcd_test.flash"
Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00000808: verified
: Checksumming existing contents
00000000 : Verifying existing contents
00010000 : Verifying existing contents
00020000 : Verifying existing contents
00030000 : Verifying existing contents
00040000 : Verifying existing contents
00000000 : Reading existing contents
00010000 : Reading existing contents
00020000 : Reading existing contents
00030000 : Reading existing contents
00040000 : Reading existing contents
Checksummed/read 320kB in 21.2s
00000000 ( 0%): Erasing
00010000 (20%): Erasing
00020000 (40%): Erasing
00030000 (60%): Erasing
00040000 (80%): Erasing
Erased 320kB in 3.0s (106.6kB/s)
00000000 ( 0%): Programming
00010000 (20%): Programming
00020000 (40%): Programming
00030000 (60%): Programming
00040000 (80%): Programming
Programmed 285KB +35KB in 15.2s (21.0KB/s)
Did not attempt to verify device contents
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="lcd_test.flash" --input="lcd_tes
t2.elf" --output="epcs_controller.flash"
# Programming flash with the project
0000808 --id=2135972589 --timestamp=1183647553 "epcs_controller.flash"
Checksummed/read 64kB in 4.2s
00040000 ( 0%): Erasing
Erased 64kB in 0.6s (106.6kB/s)
00040000 ( 0%): Programming
Programmed 34KB +30KB in 2.9s (22.0KB/s)
I
