#include <stdio.h> #include <stdlib.h> #include <unistd.h> #include <pthread.h> #include <errno.h> pthread_mutex_t mutex = PTHREAD_MUTEX_INITIALIZER; int lock_var; time_t end_time; int sum; void pthread1(void *arg); void pthread2(void *arg); void pthread3(void *arg); int main(int argc, char *argv[]) { pthread_t id1,id2,id3; pthread_t mon_th_id; int ret; sum=10; end_time = time(NULL) 10; pthread_mutex_init(&mutex,NULL); ret=pthread_create(&id1,NULL,(void *)pthread1, NULL); if(ret!=0) perror("pthread cread1"); ret=pthread_create(&id2,NULL,(void *)pthread2, NULL); if(ret!=0) perror("pthread cread2"); ret=pthread_create(&id3,NULL,(void *)pthread3, NULL); if(ret!=0) perror("pthread cread3"); pthread_join(id1,NULL); pthread_join(id2,NULL); pthread_join(id3,NULL); exit(0); } void pthread1(void *arg) { int i; while(time(NULL) < end_time) { if(pthread_mutex_lock(&mutex)!=0) //lock { perror("pthread_mutex_lock"); } else printf("pthread1:pthread1 lock the variablen"); for(i=0;i<2;i ) { sleep(2); lock_var ; } if(pthread_mutex_unlock(&mutex)!=0) //unlock { perror("pthread_mutex_unlock"); } else printf("pthread1:pthread1 unlock the variablen"); sleep(1); } } void pthread2(void *arg) { int nolock=0; int ret; while(time(NULL) < end_time) { ret=pthread_mutex_trylock(&mutex);//try lock if(ret==EBUSY) printf("pthread2:the variable is locked by pthread1n"); else{ if(ret!=0) { perror("pthread_mutex_trylock"); exit(1); } else printf("pthread2:pthread2 got lock.The variable is %dn",lock_var); if(pthread_mutex_unlock(&mutex)!=0)//unlock { perror("pthread_mutex_unlock"); } else printf("pthread2:pthread2 unlock the variablen"); } sleep(1); } } void pthread3(void *arg) {/* int nolock=0; int ret; while(time(NULL) < end_time) ret=pthread_mutex_trylock(&mutex); if(ret==EBUSY) printf("pthread3:the variable is locked by pthread1 or 2n"); else { if(ret!=0) { perror("pthread_mutex_trylock"); exit(1); } else printf("pthread3:pthread3 got lock.The variable is %dn",lock_var); if(pthread_mutex_unlock(&mutex)!=0) { perror("pthread_mutex_unlock"); } else printf("pthread3:pthread2 unlock the variablen"); } sleep(3); }*/ } |
