标题: nios i2c 读写数据程序的问题 [打印本页]
作者: gaoguoxin    时间: 2007-8-1 11:58     标题: nios i2c 读写数据程序的问题
以下是对at89c0808c加密芯片的memory test zone 读写数据的程序,但是有些数据读写正确,有些数据读写就错误,请指点!!
#include"string.h"
#include <stdio.h>
#include "altera_avalon_pio_regs.h"
#include "system.h"
#include "time.h"
#define Set_SDA  IOWR_ALTERA_AVALON_PIO_DATA(SDA_BASE, 0x1)
#define Clr_SDA  IOWR_ALTERA_AVALON_PIO_DATA(SDA_BASE, 0x0)
#define Set_SCL  IOWR_ALTERA_AVALON_PIO_DATA(SCL_BASE, 0x1)
#define Clr_SCL  IOWR_ALTERA_AVALON_PIO_DATA(SCL_BASE, 0x0)
void delay1us()
{int a1;
    for(a1=0;a1<50;a1++);
void delay1ms()
{int a2;
    for(a2=0;a2<50000;a2++);
void I2C_Start(void)
  IOWR_ALTERA_AVALON_PIO_DIRECTION(SDA_BASE, 0x1);
  IOWR_ALTERA_AVALON_PIO_DIRECTION(SCL_BASE, 0x1);
  Set_SDA;
  Set_SCL;
 delay1us();
  Clr_SDA;
 delay1us();
  Clr_SCL;
 delay1us();
void I2C_Stop(void)
  Clr_SDA;
  Clr_SCL;
 delay1us();
  Clr_SDA;
  Set_SCL;
 delay1us();
  Set_SDA;
 delay1us();
void I2C_Ack(void)
{  IOWR_ALTERA_AVALON_PIO_DIRECTION(SDA_BASE, 0x1);
  Clr_SDA;
 delay1us();
  Set_SCL;
 delay1us();
   Clr_SCL;
 delay1us();
void Check_Ack(void)
{int a=1;
IOWR_ALTERA_AVALON_PIO_DIRECTION(SDA_BASE, 0x0);
  Clr_SCL;
 delay1us();
  Set_SCL;
 delay1us();
  while(a)
     a=IORD_ALTERA_AVALON_PIO_DATA(SDA_BASE);
 delay1us();
     printf("waiting ACK .a is %d\n",a);
  delay1us();
  printf("detected ACK\n");
  Clr_SCL;
 delay1us();
void I2C_Nack(void)
  Set_SDA;
  delay1us();
  Set_SCL;
 delay1us();
  Clr_SCL;
 delay1us();
void I2C_Send_Byte(int d)
int i = 8;
 delay1us();
   Clr_SDA;
   Clr_SCL;
 delay1us();
while( i-- )
    if (d&0x80)
        Set_SDA;
    else
        Clr_SDA;
 delay1us();
       Set_SCL;
 delay1us();
       Clr_SCL;
 delay1us();
      Clr_SDA;
      Clr_SCL;
 delay1us();
    d = d << 1;
delay1us();
int I2C_Receive_Byte(void)
  { int retc,bitcnt;
           retc=0;
 delay1us();
    for(bitcnt=0;bitcnt<8;bitcnt++)
    {      Set_SCL;
      delay1ms();
       retc=retc<<1;
   if((int)IORD_ALTERA_AVALON_PIO_DATA(SDA_BASE)) retc=retc+1;
        Clr_SCL;
delay1ms();
    return(retc);
int main()
{int data[500]={0};  int cnt;
I2C_Start();
I2C_Send_Byte(0xb4);
Check_Ack();
I2C_Send_Byte(0x00);
Check_Ack();
I2C_Send_Byte(0x0a);
Check_Ack();
I2C_Send_Byte(0x02);
Check_Ack();
I2C_Send_Byte(0x39);
Check_Ack();
I2C_Send_Byte(0x8d);
Check_Ack();
I2C_Stop();
delay1ms();
I2C_Start();
I2C_Send_Byte(0xb6);
Check_Ack();
Check_Ack();
Check_Ack();
Check_Ack();
for(cnt=0;cnt<2;cnt++)
{data[cnt]=I2C_Receive_Byte();
 printf("data=%x\n",data[cnt]);
I2C_Ack();
data[cnt+1]=I2C_Receive_Byte();
printf("data=%x\n",data[cnt+1]);
I2C_Nack();
I2C_Stop();
作者: kzw    时间: 2007-8-1 17:10
I2C最简单了,看了你的代码,用IO模拟的一个I2C时序,应该没有什么问题,不知道的你延时够不够。
作者: gaoguoxin    时间: 2007-8-1 19:19     标题: 延时
延时也不应该有问题啊 不然应该一个数据都读不出来  为什么有的数据可以,有的数据不可以 ,头疼啊
作者: kzw    时间: 2007-8-2 22:41
确定你的芯片没有问题吗?延时有问题可能有的,时间正好处在你的临界可能出现这样的问题。
