JAVA流操作(2)文件流
look_w
2017-11-18 20:25
JAVA流操作(2)文件流
File f = new File("test.txt");
//构建文件对象
RandomAccessFile f = new RandomAccessFile("Hello.txt","rw");
//构建随机访问文件对象
FileOutputStream fout = new FileOutputStream(f);
//文件输出流,数据从流中写入文件FileInputStream fout = new FileInputStream(f);
//文件输入流,数据从文件中写入流
附一个中文出现乱码的解决方案:
public
static String parseChinese(String inStr)
String s = null;
byte temp[];
if (inStr == null)
return
new String("");
try
temp=inStr.getBytes("iso-8859-1");
s = new String(temp);
catch(UnsupportedEncodingException e)
System.out.println (e.toString());
return s;
