标题: VirtualApp沙盒基本原理更新 [打印本页]
作者: look_w    时间: 2017-11-18 20:53     标题: VirtualApp沙盒基本原理更新
而addHook()最终会调用到com.lody.virtual.client.hook.base.HookDelegate#addHook,其实质便是将这个hook添加至映射表internalHookTable中:
    public Hook addHook(Hook hook) {        if (hook != null && !TextUtils.isEmpty(hook.getName())) {            if (internalHookTable.containsKey(hook.getName())) {                VLog.w(TAG, "The Hook(%s, %s) you added has been in existence.", hook.getName(),                        hook.getClass().getName());                return hook;            }            internalHookTable.put(hook.getName(), hook);        }        return hook;    }internalHookTable维护了所有的hook,以hook的名称(一般就是所hook的方法的名称)作为key。随后,在com.lody.virtual.client.hook.base.HookDelegate.HookHandler的invoke()方法中,查找表 internalHookTable中是否包含将要执行的方法名;如果有,则依次执行对应hook的beforeCall(), call(), afterCall():
    private class HookHandler implements InvocationHandler {        @Override        public Object invoke(Object proxy, Method method, Object[] args) throws Throwable {            Hook hook = getHook(method.getName());            try {                if (hook != null && hook.isEnable()) {                    if (hook.beforeCall(mBaseInterface, method, args)) {                        Object res = hook.call(mBaseInterface, method, args);                        res = hook.afterCall(mBaseInterface, method, args, res);                        return res;                    }                }                return method.invoke(mBaseInterface, args);而这里的类HookHandler,就是构造的Java代理的Handler:
    public HookDelegate(T baseInterface, Class<?>... proxyInterfaces) {        this.mBaseInterface = baseInterface;        if (baseInterface != null) {            if (proxyInterfaces == null) {                proxyInterfaces = HookUtils.getAllInterface(baseInterface.getClass());            }            mProxyInterface = (T) Proxy.newProxyInstance(baseInterface.getClass().getClassLoader(), proxyInterfaces, new HookHandler());对于ActivityManagerPatch来说,这里的baseInterface便是原始的BinderProxy:ActivityManagerProxy
    public ActivityManagerPatch() {        super(new HookDelegate<IInterface>(ActivityManagerNative.getDefault.call()));    }综上,我们根据baseInterface,为其构造了代理mProxyInterface。从而访问mProxyInterface时,便会执行HookHandler的invoke()方法,进而查找internalHookTable,对设置了hook的方法执行hook。
系统服务的替换如之前所说,对系统服务的替换,是通过对应用所持有的系统服务的BinderProxy进行替换的。以上是构造代理的基本过程,那么如何将应用所持有的BinderProxy替换成我们构造的代理呢?回到ActivityManagerPatch,这个类的inject()方法完成了实际的替换工作:
    @Override    public void inject() throws Throwable {        if (ActivityManagerNative.gDefault.type() == IActivityManager.TYPE) {            ActivityManagerNative.gDefault.set(getHookDelegate().getProxyInterface());        } else if (ActivityManagerNative.gDefault.type() == Singleton.TYPE) {            Object gDefault = ActivityManagerNative.gDefault.get();            Singleton.mInstance.set(gDefault, getHookDelegate().getProxyInterface());        }        ...ActivityManagerNative.gDefault便是应用所持有的原始ActivityManagerProxy对象,通过Java反射,将替换成为getHookDelegate().getProxyInterface()。而替换的内容,便是我们所构造的代理mProxyInterface。
由此,我们完成了对系统服务进行代理和替换的整个过程。随后,在调用系统服务时,便会执行以下操作:
总结通过以上介绍可以看到,VirtualApp在原有系统服务之上构造了代理,进而为其中的应用搭建了一套虚拟环境,应用可以无感知地运行在这其中。更进一步,我们可以设置这套虚拟环境,使其实现应用多开、非侵入式应用hook等高级功能。
