1 2 3 | # make # make check # make install |
1 2 3 4 5 6 7 8 | # valgrind du –x –s . . ==29404== Address 0x1189AD84 is 0 bytes after a block of size 12 alloc'd ==29404== at 0xFFB9964: malloc (vg_replace_malloc.c:130) ==29404== by 0xFEE1AD0: strdup (in /lib/tls/libc.so.6) ==29404== by 0xFE94D30: setlocale (in /lib/tls/libc.so.6) ==29404== by 0x10001414: main (in /usr/bin/du) |
1 2 3 4 5 6 7 | 2 { 3 int i[5]; 4 5 if (i[0] == 0) 6 i[1]=1; 7 return 0; 8 } |
1 2 3 4 5 6 7 8 9 10 11 12 13 | # gcc –g –o test1 test1.c # valgrind ./test1 . . ==31363== ==31363== Conditional jump or move depends on uninitialised value(s) ==31363== at 0x1000041C: main (test1.c:5) ==31363== ==31363== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 7 from 1) ==31363== malloc/free: in use at exit: 0 bytes in 0 blocks. ==31363== malloc/free: 0 allocs, 0 frees, 0 bytes allocated. ==31363== For counts of detected errors, rerun with: -v ==31363== No malloc'd blocks -- no leaks are possible. |
1 2 3 4 5 6 7 8 9 10 11 12 13 | 1 int main(void) 2 { 3 char *p1; 4 char *p2; 5 6 p1 = (char *) malloc(512); 7 p2 = (char *) malloc(512); 8 9 p1=p2; 10 11 free(p1); 12 free(p2); 13 } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 | # gcc –g –o test2 test2.c # valgrind ./test2 . . ==31468== Invalid free() / delete / delete[] ==31468== at 0xFFB9FF0: free (vg_replace_malloc.c:152) ==31468== by 0x100004B0: main (test2.c:12) ==31468== Address 0x11899258 is 0 bytes inside a block of size 512 free'd ==31468== at 0xFFB9FF0: free (vg_replace_malloc.c:152) ==31468== by 0x100004A4: main (test2.c:11) ==31468== ==31468== ERROR SUMMARY: 1 errors from 1 contexts (suppressed: 7 from 1) ==31468== malloc/free: in use at exit: 512 bytes in 1 blocks. ==31468== malloc/free: 2 allocs, 2 frees, 1024 bytes allocated. ==31468== For counts of detected errors, rerun with: -v ==31468== searching for pointers to 1 not-freed blocks. ==31468== checked 167936 bytes. ==31468== ==31468== LEAK SUMMARY: ==31468== definitely lost: 512 bytes in 1 blocks. ==31468== possibly lost: 0 bytes in 0 blocks. ==31468== still reachable: 0 bytes in 0 blocks. ==31468== suppressed: 0 bytes in 0 blocks. ==31468== Use --leak-check=full to see details of leaked memory. |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 | 1 int main() { 2 int i, *iw, *ir; 3 4 iw = (int *)malloc(10*sizeof(int)); 5 ir = (int *)malloc(10*sizeof(int)); 6 7 8 for (i=0; i<11; i++) 9 iw = i; 10 11 for (i=0; i<11; i++) 12 ir = iw; 13 14 free(iw); 15 free(ir); 16 } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 | # gcc –g –o test3 test3.c # valgrind ./test3 . . ==31522== Invalid write of size 4 ==31522== at 0x100004C0: main (test3.c:9) ==31522== Address 0x11899050 is 0 bytes after a block of size 40 alloc'd ==31522== at 0xFFB9964: malloc (vg_replace_malloc.c:130) ==31522== by 0x10000474: main (test10.c:4) ==31522== ==31522== Invalid read of size 4 ==31522== at 0x1000050C: main (test3.c:12) ==31522== Address 0x11899050 is 0 bytes after a block of size 40 alloc'd ==31522== at 0xFFB9964: malloc (vg_replace_malloc.c:130) ==31522== by 0x10000474: main (test10.c:4) ==31522== ==31522== ERROR SUMMARY: 2 errors from 2 contexts (suppressed: 7 from 1) ==31522== malloc/free: in use at exit: 0 bytes in 0 blocks. ==31522== malloc/free: 2 allocs, 2 frees, 84 bytes allocated. ==31522== For counts of detected errors, rerun with: -v ==31522== No malloc'd blocks -- no leaks are possible. |
