1 | telnetd,sshd:192.168.4.: allow |
1 2 3 4 5 6 7 | # tcpdmatch telnetd 192.168.4.12 tcpdmatch telnetd 192.168.4.12 client: address 192.168.4.12 server: process telnetd matched:/etc/hosts.allow line 1 option: allow access: granted |
1 2 3 4 5 6 | # tcpdmatch ftpd 192.168.4.12 client: address 192.168.4.12 server: process ftpd matched:/etc/hosts.deny line 1 option: DENY access: denied |
1 2 3 4 5 6 7 | # tcpdmatch sshd 192.168.6.32 warning: sshd: no such process name in /etc/inetd.conf client: address 192.168.6.32 server: process sshd matched:/etc/hosts.deny line 1 option: DENY access: denied |
1 | Your connection has been refused.Access denied and the event is logged |
1 2 3 4 5 6 7 8 | # pwd /etc/banners/deny # ls ftpd telnetd # cat telnetd Your connection has been refused. Access denied and the event is logged |
1 | All:ALL: banners /etc/banners/deny ENY |
1 2 3 | $ tn rs6000 Your connection has been refused. Access denied and the event is logged |
1 | twist 'shell command' |
1 2 | sshd,telnetd:192.168.9.14: twist /bin/echo "Your connection has been refused\ \nAccess denied and the event is logged" |
1 | spawn '(shell command)' |
1 2 | telnetd,sshd:192.168.9.24 : spawn (/usr/bin/logger 'DEV BOX!!Warning!!\: %a has connected') :allow |
1 2 | Oct 24 15:47:22 rs6000 user:notice rootEV BOX!!Warning!!:192.168.9.24 has connected Oct 24 15:47:22 rs6000 auth|security telnetd[245806]: connect from uk01dev002 |
1 2 | telnetd,sshd:192.168.9.24 : spawn (/usr/bin/logger '* DEV BOX *!!Warning!!\: %a has tried to connected') :deny |
1 2 3 4 | Oct 24 20:02:39 rs6000 user:notice root:* DEV BOX *!!Warning!!:192.168.9.24 Tried to connect Oct 24 20:02:39 rs6000 auth|security|warning telnetd[237744]: refused connect from uk01dev002 |
1 2 | telnetd,sshd:192.168.9.24 : spawn (/usr/bin/echo 'DEV BOX!Warning %a has connected' |/usr/bin/mail secport) :allow |
