1 | yum install -y yum-utils |
1 2 | yum-config-manager --add-repo https://docs.docker.com/v1.13/en ... /centos/docker.repo yum makecache fast |
1 2 3 | # 查看 docker-engine 的所有版本,找到期望版本的精确名字,如 1.12.6-1.el7.centos yum list docker-engine --showduplicates yum -y install docker-engine-1.12.6-1.el7.centos |
1 2 | systemctl start docker systemctl enable docker |
1 2 3 4 | yum list installed | grep docker yum remove -y docker_name yum-config-manager --disable address_of_repository_for_existing_Docker_version |
1 | rm -rf /var/lib/docker |
1 | yum -y install docker-engine-1.12.6-1.el7.centos |
1 | [root@dashdb mnt]# <strong>mkdir /mnt/clusterfs/</strong> |
1 2 | [root@dashdb mnt]# <strong>echo "ENABLE_ORACLE_COMPATIBILITY='YES'" >> /mnt/clusterfs/options</strong> |
1 2 3 4 | [root@dashdb mnt]#<strong> echo "SPARK_MEM_SHARE=20">>/mnt/clusterfs/options</strong> [root@dashdb mnt]# cat /mnt/clusterfs/options ENABLE_ORACLE_COMPATIBILITY='YES' SPARK_MEM_SHARE=20 |
