1 2 3 4 5 6 | !threads { Thread ID: 0x74c9 (29897) IP: 0x0000000000eb112d !stack 29897 } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 | !stack 29897 { Instruction Pointer Frame Address Location / Frame Type ------------------- ------------------ ------------------------------------------------------------------------------------ 0x0000000000eb112d 0x00007FFF0A81F960 node::_ZN2v84base2OS11GetUserTimeEPjS2_+0x9d 0x0000000000a890c1 0x00007FFF0A81FAC0 node::_ZN2v88internal7Isolate29CaptureAndSetSimpleStackTraceENS0_6HandleINS0_8JSO... 0x0000000000b63c9d 0x00007FFF0A81FAF0 node::_ZN2v88internal25Runtime_ThrowNotDateErrorEiPPNS0_6ObjectEPNS0_7IsolateE+0xdd 0x00000E7CAA2A8E32 0x00007FFF0A81FB40 main [/home/sian/test.js] !jsobject 0x00001519ED09B451 0x00000E7CAA2A8B34 0x00007FFF0A81FB78 <anonymous> [/home/sian/test.js] !jsobject 0x00001519ED09B341 0x00000E7CAA224AC6 0x00007FFF0A81FBE0 INTERNAL FRAME 0x00000E7CAA2A7D26 0x00007FFF0A81FC58 Module._compile [module.js] !jsobject 0x00000DA39E6185F9 0x00000E7CAA2A220C 0x00007FFF0A81FCA0 Module._extensions..js [module.js] !jsobject 0x00000DA39E618691 0x00000E7CAA29E940 0x00007FFF0A81FCE8 Module.load [module.js] !jsobject 0x00000DA39E618569 0x00000E7CAA295565 0x00007FFF0A81FD70 Module._load [module.js] !jsobject 0x00000DA39E6184D9 0x00000E7CAA294F24 0x00007FFF0A81FDB8 Module.runMain [module.js] !jsobject 0x00000DA39E618721 0x00000E7CAA26B31F 0x00007FFF0A81FE28 startup [node.js] !jsobject 0x0000079578AC8A61 0x00000E7CAA269D10 0x00007FFF0A81FE58 <anonymous> [node.js] !jsobject 0x0000079578A6EF49 0x00000E7CAA21EF40 0x00007FFF0A81FE98 INTERNAL FRAME 0x00000E7CAA21DE90 0x00007FFF0A81FF20 ENTRY FRAME 0x00000E7CAA21DE90 0x00007FFF0A81FF20 ENTRY FRAME 0x0000000000914E28 0x00007FFF0A81FFF0 NONE FRAME 0x0000000000813bda 0x00007FFF0A820060 node::_ZN2v88Function4CallENS_6HandleINS_5ValueEEEiPS3_+0xba 0x0000000000c9d40f 0x00007FFF0A820190 node::_ZN4node15LoadEnvironmentEPNS_11EnvironmentE+0x1df 0x0000000000c9d67f 0x00007FFF0A8202E0 node::_ZN4node15LoadEnvironmentEPNS_11EnvironmentE+0x44f 0x0000003d0fa1ed5d 0x0000000000000000 node::_fini+0x3d0eb6c8c5 } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 | !jsobject 0x00001519ED09B451 { Object has fast properties Number of descriptors : 5 Name Value More Information --------- ------------------ ------------------------------- length 0x0000079578A0FE19 <EXECUTABLE_ACCESSOR_INFO_TYPE> name 0x0000079578A0FE51 <EXECUTABLE_ACCESSOR_INFO_TYPE> arguments 0x0000079578A0FE89 <EXECUTABLE_ACCESSOR_INFO_TYPE> caller 0x0000079578A0FEC1 <EXECUTABLE_ACCESSOR_INFO_TYPE> prototype 0x0000079578A0FEF9 <EXECUTABLE_ACCESSOR_INFO_TYPE> Object is a function Name: main Source: () { var inputObject = { input: ["one", "two", "three", "fifteen", "one hundred"], counter:0, }; for(; inputObject.counter< inputObject.input.length; inputObject.counter++) { if (inputObject.input[inputObject.counter].length > 8) { throw "Input String Too Big"; } } } } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 | !jsfindbyproperty counter { !jsobject 0x00001519ED09B539 !jsobject 0x00001519ED09B689 } !jsobject 0x00001519ED09B689 { Object has fast properties Number of descriptors : 2 Name Value More Information ------- ------------------ --------------------------------------------- input 0x00001519ED09B6C1 <JS Array[5]> :- !jsobject 0x00001519ed09b6c1 counter 0x0000000400000000 SMI = 4 } |
1 2 3 4 5 6 7 8 9 10 11 12 | !jsobject 0x00001519ed09b6c1 { Array at !hexdump 0x00001519ED09B4E1 Array len = 5 0 : 0x00000CEAAC1A3679, one 1 : 0x00000CEAAC1A3699, two 2 : 0x00000CEAAC1A36B9, three 3 : 0x00000CEAAC1A36D9, fifteen 4 : 0x00000CEAAC1A36F9, one hundred } |
