1 2 3 4 5 6 7 8 9 10 11 12 | Command (m for help): p Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes 256 heads, 63 sectors/track, 242251 cylinders, total 3907029168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Device Boot Start End Blocks Id System /dev/sdb1 2048 2097151 1047552 83 Linux /dev/sdb2 2097152 3907029167 1952466008 83 Linux |
1 2 3 4 5 6 7 8 9 10 11 | (parted) unit s (parted) print Model: ATA ST2000DL003-9VT1 (scsi) Disk /dev/sdb: 3907029168s Sector size (logical/physical): 512B/512B Partition Table: gpt Disk Flags: Number Start End Size File system Name Flags 1 2048s 2097151s 2095104s ntfs Windows 2 2097152s 3907029167s 3904932016s Linux |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 | Command (? for help): p Disk /dev/sdb: 3907029168 sectors, 1.8 TiB Logical sector size: 512 bytes Disk identifier (GUID): 4B18D328-5E8E-49DB-8690-9FE89807ABF8 Partition table holds up to 128 entries First usable sector is 34, last usable sector is 3907029134 Partitions will be aligned on 8-sector boundaries Total free space is 6 sectors (3.0 KiB) Number Start (sector) End (sector) Size Code Name 1 40 409639 200.0 MiB 8300 Unused /boot 2 409640 819239 200.0 MiB 8300 Unused /boot 3 819240 3907029134 1.8 TiB 8E00 Linux LVM Command (? for help): v No problems found. 6 free sectors (3.0 KiB) available in 1 segments, the largest of which is 6 (3.0 KiB) in size. |
