1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 | // generated by named-bootconf.pl options { directory "/var/named"; /* * If there is a firewall between you and nameservers you want * to talk to, you might need to uncomment the query-source * directive below. Previous versions of BIND always asked * questions using port 53, but BIND 8.1 uses an unprivileged * port by default. */ // query-source address * port 53; }; // // a caching only nameserver config // zone "." { type hint; file "named.ca"; }; zone "0.0.127.in-addr.arpa" { type master; file "named.local"; }; zone "feixiang.com"{ type slave; file "named.hosts"; masters {25.198.10.3;}; }; zone "198.25.in-addr.arpa"{ type slave; file "named.rev"; masters {25.198.10.3;}; }; cache . named.ca secondary vbrew.com 25.198.10.3 named.hosts secondary 198.25.in-addr.arpa 25.198.10.3 named.rev primary 0.0.127.in-addr.arpa named.local |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 | // generated by named-bootconf.pl options { directory "/var/named"; /* * If there is a firewall between you and nameservers you want * to talk to, you might need to uncomment the query-source * directive below. Previous versions of BIND always asked * questions using port 53, but BIND 8.1 uses an unprivileged * port by default. */ // query-source address * port 53; }; // // a caching only nameserver config // // // a caching only nameserver config // zone "." { type hint; file "named.ca"; }; zone "0.0.127.in-addr.arpa" { type master; file "named.local"; |
1 2 3 4 5 6 | web_server1INA210.113.1.1 web_server2INA210.113.1.2 web_server3INA210.113.1.3 wwwINCNAMEweb_server1 wwwINCNAMEweb_server2 wwwINCNAMEweb_server3 |
