1 2 3 4 5 | PS C:\Program Files\Docker Toolbox> docker-machine rm default About to remove default Are you sure? (y/n): y Successfully removed default PS C:\Program Files\Docker Toolbox> |
1 | docker-machine create -d virtualbox --virtualbox-disk-size "40000" --virtualbox-memory "4096" --virtualbox-cpu-count "1" default |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 | PS C:\Program Files\Docker Toolbox> docker-machine create -d virtualbox --virtualbox-disk-size "40000" --virtualbox-memory "4096"--virtualbox-cpu-count "1" default Running pre-create checks... Creating machine... (default) Copying C:\Users\gyzhang\.docker\machine\cache\boot2docker.iso to C:\Users\gyzhang\.docker\machine\machines\default\boot2docker.iso... (default) Creating VirtualBox VM... (default) Creating SSH key... (default) Starting the VM... (default) Check network to re-create if needed... (default) Waiting for an IP... Waiting for machine to be running, this may take a few minutes... Detecting operating system of created instance... Waiting for SSH to be available... Detecting the provisioner... Provisioning with boot2docker... Copying certs to the local machine directory... Copying certs to the remote machine... Setting Docker configuration on the remote daemon... Checking connection to Docker... Docker is up and running! To see how to connect your Docker Client to the Docker Engine running on this virtual machine, run: C:\Program Files\Docker Toolbox\docker-machine.exe env default PS C:\Program Files\Docker Toolbox> |
1 | PS C:\Program Files\Docker Toolbox> docker-machine env default |
1 2 | PS C:\Program Files\Docker Toolbox> docker exec -it dashDB setpass passw0rd Password successfully updated |
1 | PS C:\Program Files\Docker Toolbox> docker start dashDB |
1 | PS C:\Program Files\Docker Toolbox> docker exec -it dashDB start |
1 | PS C:\Program Files\Docker Toolbox> docker exec -it dashDB stop |
1 | PS C:\Program Files\Docker Toolbox> docker stop dashDB |
1 2 3 | PS C:\Program Files\Docker Toolbox> docker ps CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES 5e39cb0a9861 ibmdashdb/local:v1.2.0-kitematic "/usr/sbin/init" 37 minutes ago Up 37 minutes 0.0.0.0:8443->8443/tcp, 0.0.0.0:25000-25999->25000-25999/tcp,0.0.0.0:50000-50001->50000-50001/tcp, 0.0.0.0:50022->22/tcp dashDB |
1 2 3 | PS C:\Program Files\Docker Toolbox> docker ps -a CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES 5e39cb0a9861 ibmdashdb/local:v1.2.0-kitematic "/usr/sbin/init" 37 minutes ago Up 37 minutes 0.0.0.0:8443->8443/tcp, 0.0.0.0:25000-25999->25000-25999/tcp,0.0.0.0:50000-50001->50000-50001/tcp, 0.0.0.0:50022->22/tcp dashDB |
1 2 3 4 5 | PS C:\Program Files\Docker Toolbox> docker images REPOSITORY TAG IMAGE ID CREATED SIZE ibmdashdb/local v1.2.0-kitematic 900133686cf6 7 days ago 5.296 GB |
1 2 | gyzhang@DB2DEMO-W520 MINGW64 ~ $ docker start dashDB |
1 2 | gyzhang@DB2DEMO-W520 MINGW64 ~ $ docker exec -it dashDB start |
1 2 | gyzhang@DB2DEMO-W520 MINGW64 ~ $docker exec -it dashDB stop |
1 2 | gyzhang@DB2DEMO-W520 MINGW64 ~ $ docker stop dashDB |
1 2 3 4 | gyzhang@DB2DEMO-W520 MINGW64 ~ $ docker ps CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES 5e39cb0a9861 ibmdashdb/local:v1.2.0-kitematic "/usr/sbin/init" 37 minutes ago Up 37 minut 0.0.0.0:8443->8443/tcp, 0.0.0.0:25000-25999->25000-25999/tcp, 0.0.0.0:50000-50001->50000-50001/tcp, 0.0.0.0:50022->22/tcp dashDB |
1 2 3 4 5 | gyzhang@DB2DEMO-W520 MINGW64 ~ $ docker ps -a CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES 5e39cb0a9861 ibmdashdb/local:v1.2.0-kitematic "/usr/sbin/init" 37 minutes ago Up 37 minutes 0.0.0.0:8443->8443/tcp, 0.0.0.0:25000-25999->25000-25999/tcp, 0.0.0.0:50000-50001->50000-50001/tcp, 0.0.0.0:50022->22/tcp dashDB |
1 2 3 4 5 | gyzhang@DB2DEMO-W520 MINGW64 ~ $ docker images REPOSITORY TAG IMAGE ID CREATED SIZE ibmdashdb/local v1.2.0-kitematic 900133686cf6 7 days ago 5.296 GB |
