1 2 3 4 5 6 7 8 9 | {"result":{"date":"2017-10- 03T17:07:21.819Z","data":{"creg_labels":"c[5]","p": {"qubits":[1,2],"labels":["00110"],"values":[1]}, "additionalData":{"seed":1},"qasm ... ,"userDeleted":false,"id":"7012d29df79ba1fca3e5eda009069d3d", "userId":"a3e5c196cb90688ba9a50dd7607999a6"}} |
1 2 3 | QExecutionOutput x= JsonConvert.DeserializeObject <QExecutionOutput>(result.Message); Debug.WriteLine("The values are: " + x.result.data.p.labels[0]); |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 | //parse the result and output the location of the coin QExecutionOutput x = qp.GetOutputFromMessageData(result.Message); string labels = x.result.data.p.labels[0]; switch (labels) { case "00000": Debug.WriteLine("The coin was under Shell #1"); ComputedShell.Value = "1"; break; case "00100": Debug.WriteLine("The coin was under Shell #2"); ComputedShell.Value = "2"; break; case "00010": Debug.WriteLine("The coin was under Shell #3"); ComputedShell.Value = "3"; break; case "00110": Debug.WriteLine("The coin was under Shell #4"); ComputedShell.Value = "4"; break; default: Debug.WriteLine("Something broke!"); ComputedShell.Value = "0"; break; } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 | [HttpPost] public IActionResult Index(ShellGameModel model) { model.ComputedShell = "0"; model.QASM = ""; model.ExecutionResults = ""; string token = "INSERTYOURTOKENHERE"; //Build the processor QProcessor qp = new QProcessor(token); //login QResult result = qp.Login(); Debug.WriteLine(string.Format("Login result. Success={0} Message={1}", result.Success.ToString(), result.Message)); if (result.Success) { int shell = 0; Int32.TryParse(model.ShellSelected, out shell); //build the QASM code QCode code = new QCode(shell); code.name = string.Format("ExperimentID {0} with Shell at {1} ", System.Guid.NewGuid().ToString(), shell.ToString()); Debug.WriteLine("Code:" + Environment.NewLine + code.qasm); //execute the code result = qp.ExecuteCode(code); Debug.WriteLine(string.Format("Code Executed Success={0}, Data={1}", result.Success.ToString(), result.Message)); //parse the result and output the location of the coin QExecutionOutput x = qp.GetOutputFromMessageData(result.Message); string labels = x.result.data.p.labels[0]; switch (labels) { case "00000": Debug.WriteLine("The coin was under Shell #1"); model.ComputedShell = "1"; break; case "00100": Debug.WriteLine("The coin was under Shell #2"); model.ComputedShell = "2"; break; case "00010": Debug.WriteLine("The coin was under Shell #3"); model.ComputedShell = "3"; break; case "00110": Debug.WriteLine("The coin was under Shell #4"); model.ComputedShell = "4"; break; default: Debug.WriteLine("Something broke!"); model.ComputedShell = "0"; break; } model.QASM = JsonConvert.SerializeObject(x.code, Formatting.Indented); model.ExecutionResults = JsonConvert.SerializeObject(x.result, Formatting.Indented); //now cleanup and delete the results QResult deleteResult = qp.DeleteExperiment(x.code.idCode); } return View(model); } |
