1 | org=vs9qqv type=PTK-STM32F207 id=beefbeef0002 auth-method=token auth-token=X*l5X!(SkF&c3RJVN@ |
1 | ping vs9qqv.messaging.internetofthings.ibmcloud.com |
1 | ...#ifndef USE_DNS #undef MQTT_HOST_NAME #define MQTT_HOST_IP "23.246.232.210" ...#if (0) //Quickstart Mode ...#else //Registered Mode #define ORG "vs9qqv" //Replace with your org #define DEVICE_TYPE "PTK-STM32F207" // #define AUTH_METHOD "token" // #define AUTH_TOKEN "X*l5X!(SkF&c3RJVN@"//Replace with your auth-token #endif ... |
1 | var out_msg = { "payload" :JSON.stringify(msg.payload) }; return out_msg; |
