1 | #dbx <program name> core |
1 2 3 4 5 6 7 8 9 | # dbx ./test core Type 'help' for help. warning: The core file is not a fullcore. Some info may not be available. [using memory image in core] reading symbolic information ...warning: no source compiled with -g Segmentation fault in raise at 0xd022e1e4 0xd022e1e4 (raise+0x40) 80410014 lwz r2,0x14(r1) |
1 2 3 | (dbx) where raise(??) at 0xd022e1e4 main(0x1, 0x2ff22d48) at 0x100019c4 |
1 2 3 4 5 6 7 8 9 | # cd /tmp/snapcore # dbx –p /=./ a.out core Type 'help' for help. [using memory image in core] reading symbolic information ...warning: no source compiled with -g IOT/Abort trap in raise at 0xd01f4f60 0xd01f4f60 (raise+0x40) 80410014 lwz r2,0x14(r1) |
1 2 3 4 5 6 7 8 9 | (dbx) listi main 0x10001924 (main) 7c0802a6 mflr r0 0x10001928 (main+0x4) bfa1fff4 stmw r29,-12(r1) 0x1000192c (main+0x8) 90010008 stw r0,0x8(r1) 0x10001930 (main+0xc) 9421ffa0 stwu r1,-96(r1) 0x10001934 (main+0x10) 83e20064 lwz r31,0x64(r2) 0x10001938 (main+0x14) 90610078 stw r3,0x78(r1) 0x1000193c (main+0x18) 9081007c stw r4,0x7c(r1) 0x10001940 (main+0x1c) 83a20068 lwz r29,0x68(r2) |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 | #include <iostream> #include <signal.h> int g_test =0; int testfunc(int ¶) { para++; return 0; } int main(int argc, char* argv[]) { struct sigaction s; s.sa_handler = SIG_DFL; s.sa_mask.losigs = 0; s.sa_mask.hisigs = 0; s.sa_flags = SA_FULLDUMP; sigaction(SIGSEGV,&s,(struct sigaction *) NULL); char str[10]; g_test =0; testfunc(g_test); abort(); } # xlC test.C -g |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 | # ./a.out IOT/Abort trap(coredump) # dbx ./a.out core Type 'help' for help. [using memory image in core] reading symbolic information ... IOT/Abort trap in raise at 0xd03365bc 0xd03365bc (raise+0x40) 80410014 lwz r2,0x14(r1) (dbx) print g_test 1 (dbx) whatis g_test int g_test; (dbx) print sizeof(g_test) 4 (dbx) print &g_test 0x20000428 (dbx) &g_test/16x 0x20000428: 0000 0001 0000 0000 0000 0000 0000 0000 0x20000438: 0000 0000 0000 0000 0000 0000 0000 0000 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 | # dbx ./a.out core Type 'help' for help. warning: The core file is not a fullcore. Some info may not be available. [using memory image in core] reading symbolic information ...warning: no source compiled with -g Segmentation fault in main at 0x10000348 0x10000348 (main+0x18) 90640000 stw r3,0x0(r4) (dbx) where main(0x1, 0x2ff22ccc) at 0x10000348 (dbx) registers $r0:0x00000000 $stkp:0x2ff22bf0 $toc:0x20000414 $r3:0x00000012 $r4:0x00000000 $r5:0x2ff22cd4 $r6:0xdeadbeef $r7:0x2ff22ff8 $r8:0x00000000 $r9:0x04030000 $r10:0xf0577538 $r11:0xdeadbeef $r12:0xdeadbeef $r13:0xdeadbeef $r14:0x00000001 $r15:0x2ff22ccc $r16:0x2ff22cd4 $r17:0x00000000 $r18:0xdeadbeef $r19:0xdeadbeef $r20:0xdeadbeef $r21:0xdeadbeef $r22:0xdeadbeef $r23:0xdeadbeef $r24:0xdeadbeef $r25:0xdeadbeef $r26:0xdeadbeef $r27:0xdeadbeef $r28:0xdeadbeef $r29:0xdeadbeef $r30:0xdeadbeef $r31:0xdeadbeef $iar:0x10000348 $msr:0x0000d0b2 $cr:0x22282489 $link:0x100001b4 $ctr:0xdeadbeef $xer:0x20000020 Condition status = 0:e 1:e 2:e 3:l 4:e 5:g 6:l 7:lo [unset $noflregs to view floating point registers] [unset $novregs to view vector registers] in main at 0x10000348 0x10000348 (main+0x18) 90640000 stw r3,0x0(r4) (dbx) print $r3 0x00000012 (dbx) print $r4 (nil) |
