$ docker run --name composer-playground --publish 8080:8080 hyperledger/composer-playground
0|composer | PlaygroundAPI :createServer() > 8080
0|composer | ConnectionProfileManager :constructor() Created a new ConnectionProfileManager {"fs":{"constants":{"O_RDONLY":0,"O_WRONLY":1,"O_RDWR":2,"S_IFMT":61440,"S_IFREG":32768,"S_IFDIR":16384,"S_IFCHR":8192,"S_IFBLK":24576,"S_IFIFO":4096,"S_IFLNK":40960,"S_IFSOCK":49152,"O_CREAT":64,"O_EXCL":128,"O_NOCTTY":256,"O_TRUNC":512,"O_APPEND":1024,"O_DIRECTORY":65536,"O_NOATIME":262144,"O_NOFOLLOW":131072,"O_SYNC":1052672,"O_DIRECT":16384,"O_NONBLOCK":2048,"S_IRWXU":448,"S_IRUSR":256,"S_IWUSR":128,"S_IXUSR":64,"S_IRWXG":56,"S_IRGRP":32,"S_IWGRP":16,"S_IXGRP":8,"S_IRWXO":7,"S_IROTH":4,"S_IWOTH":2,"S_IXOTH":1,"F_OK":0,"R_OK":4,"W_OK":2,"X_OK":1},"F_OK":0,"R_OK":4,"W_OK":2,"X_OK":1}}
0|composer | PlaygroundAPI :createServer() Playground API started on port 8080
0|composer | PlaygroundAPI :createServer() <
0|composer | Composer :main() >
