1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 | { "Identifier": "string", "What": "This is a critical alert.", "Where": "IBM Cloud", "Severity": "Critical", "When": "Unknown Type: string, integer", "Type": "Problem", "Source": "string", "ApplicationsOrServices": [ "string" ], "URLs": [ { "Description": "string", "URL": "string" } ], "Details": [ { "Name": "test", "Value": "This is a critical alert!" } ], "EmailMessageToSend": { "Subject": "A critical alert!", "Body": "Hi, you received a critical alert!" }, "SMSMessageToSend": "string", "VoiceMessageToSend": "string" } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 | { "Identifier": "string", "What": "This is a fatalalert.", "Where": "IBM Cloud", "Severity": "Fatal", "When": "Unknown Type: string, integer", "Type": "Problem", "Source": "string", "ApplicationsOrServices": [ "string" ], "URLs": [ { "Description": "string", "URL": "string" } ], "Details": [ { "Name": "test", "Value": "This is a fatal alert!" } ], "EmailMessageToSend": { "Subject": "A fatal alert!", "Body": "Hi, you received a fatal alert!" }, "SMSMessageToSend": " A fatal alert!", "VoiceMessageToSend": " Hi, you received a fatal alert!" } |
