Reading System ID at address 0x00401898: does not match
ID value does not match: read 0x997AD0CE; expected 0xD5D175D6
Timestamp value does not match: image on board is older than expected
Read timestamp 17:33:32 2007/07/10; expected 23:18:40 2007/08/15
The software you are downloading may not run on the system which is currently
configured into the device. Please download the correct SOF or recompile.
Restarting target processor
有人知道這可能是怎麼回事嗎?
我拿以前在別台PC上做好的project直接下到fpga是沒問題的
可是只要重新compilation之後就會出現這個問題
我想...是不是tool本身出問題的機會比較大?
[此贴子已经被作者于2007-8-16 19:50:51编辑过]
好吧...我的問題解決了...我自己回答...
最原本我是使用QII5.1, Nios II 5.1, MegaCore5.1
換電腦QII5.1, Nios II 5.0, MegaCore5.0 出問題...
最後全部裝5.1就好了...
晕,原来是q2和nios2不匹配。还从来没有装过不匹配的这两个。
