1 2 3 4 5 6 7 | 1 Executing: %prep 2 + umask 022 3 + cd /usr/src/dist/BUILD 4 + exit 0 5 Executing: %build 6 + umask 022 7 + cd /usr/src/dist/BUILD |
1 | rpmbuild -bs xxx.spec |
1 | rpmbuild -bp xxx.spec |
1 | rpmbuild -ba xxx.spec |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 | %define debug_package %{nil} Name: kaffeine Version: 0.4.3 Release: 25 Summary: A xine-based Media Player for KDE Group: Applications/Multimedia License: GPL URL: http://kaffeine.sourceforge.net/ Source0: kaffeine-0.4.3.tar.bz2 Source1: logo.png Source2: icon.tgz Source3: kaffeine.desktop Source4: codecs.tgz Patch: kaffeine-0.4.3-fix-hide-crash.patch Patch1:kaffeine-0.4.3-without-wizard.patch BuildRoot: /var/tmp/kaffeine-root %description Kaffeine is a xine based media player for KDE3. It plays back CDs, DVDs, and VCDs. It also decodes multimedia files like AVI, MOV, WMV, and MP3 from local disk drives, and displays multimedia streamed over the Internet. It interprets many of the most common multimedia formats available - and some of the most uncommon formats, too. Additionally, Kaffeine is fully integrated in KDE3, it supports Drag and Drop and provides an editable playlist, a bookmark system, a Konqueror plugin, a Mozilla plugin, OSD an much more. |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 | %prep %setup -q %patch -p1 %patch1 -p1 %Build make -f admin/Makefile.common cvs ./configure --prefix=/usr make #for mo files pushd po rm *.gmo make popd %install mkdir -p $RPM_BUILD_ROOT make install DESTDIR=$RPM_BUILD_ROOT mkdir -p $RPM_BUILD_ROOT/usr/share/services cp $RPM_BUILD_ROOT/usr/share/apps/kaffeine/mms.protocol $RPM_BUILD_ROOT/usr/share/services cp $RPM_BUILD_ROOT/usr/share/apps/kaffeine/rtsp.protocol $RPM_BUILD_ROOT/usr/share/services #mkdir -p $RPM_BUILD_ROOT/usr/lib/firefox/plugins #cp $RPM_BUILD_ROOT/usr/lib/kaffeineplugin/kaffeineplugin.so $RPM_BUILD_ROOT/usr/lib/firefox/plugins cp %{SOURCE1} $RPM_BUILD_ROOT/usr/share/apps/kaffeine rm -rf $RPM_BUILD_ROOT/usr/share/icons/hicolor/*/apps/kaffeine.png rm -rf $RPM_BUILD_ROOT/usr/share/icons/hicolor/*/apps/kaffeine-pause.png rm -rf $RPM_BUILD_ROOT/usr/share/icons/hicolor/*/apps/kaffeine-play.png rm -rf $RPM_BUILD_ROOT/usr/share/icons/hicolor/*/apps/kaffeine-record.png mkdir -p $RPM_BUILD_ROOT/usr/share/icons/crystalsvg tar zxvf %{SOURCE2} -C $RPM_BUILD_ROOT/usr/share/icons/crystalsvg mkdir -p $RPM_BUILD_ROOT/usr/share/applnk/App/Multimedia cp -r %{SOURCE3} $RPM_BUILD_ROOT/usr/share/applnk/App/Multimedia mkdir -p $RPM_BUILD_ROOT/usr/lib/win32 tar zxvf %{SOURCE4} -C $RPM_BUILD_ROOT/usr/lib/win32 %clean rm -rf $RPM_BUILD_ROOT %post ln -s /dev/cdrom /dev/dvd ln -s /dev/cdrom /dev/rdvd %files %defattr(-,root,root) /usr |
1 2 3 4 5 6 7 8 9 10 | %changelog * Fri Jul 1 2005 AiLin Yang <alyang@redflag-linux.com> -0.4.3-25 - modified the fullscreen bottom control panel * Fri Jun 17 2005 xxx <xxx@redflag-linux.com> -0.4.3-24 - Modified to use xshm as video driver. * Thu Jun 16 2005 AiLin Yang <alyang@redflag-linux.com> - delete the option of Embed in system tray in configwidget * Tue Jun 14 2005 AiLin Yang <alyang@redflag-linux.com> - add fullscreen bottom control panel - update kaffine to support my fullscreen bottom control panel |
