1 2 3 4 5 6 7 8 9 10 | # dmesg |grep scsi vio_register_driver: driver ibmvscsi registering ibmvscsi 30000002: SRP_VERSION: 16.a scsi0 : IBM POWER Virtual SCSI Adapter 1.5.9 ibmvscsi 30000002: partner initialization complete ibmvscsi 30000002: sent SRP login ibmvscsi 30000002: SRP_LOGIN succeeded ibmvscsi 30000002: host srp version: 16.a, host partition vios (1), OS 3, max io 1048576 sd 0:0:1:0: Attached scsi disk sda sd 0:0:1:0: Attached scsi generic sg0 type 0 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 | # lsdev -CHc disk name status location description hdisk0 Available 01-08-00-1,0 SCSI Disk Drive 上面的命令给出了系统可用的硬盘信息,从上面的输出可以看出,系统有一个可用的 SCSI 硬盘,如果要获得硬盘的配置信息,可以使用 lscfg 来查看。 # lscfg -vl hdisk0 hdisk0 U788D.001.99DZG0B-P1-T10-L1-L0 SCSI Disk Drive (36400 MB) Manufacturer................IBM-ESXS Machine Type and Model......ST936701SS FRU Number..................39R7368 ROS Level and ID............42353142 Serial Number...............3LC0BGY8 EC Level....................H17923E Part Number.................26K5266 Device Specific.(Z0)........000005129F00100A Device Specific.(Z1)........0106B51B Device Specific.(Z2)........1000 Device Specific.(Z3)........06114 Device Specific.(Z4)........0001 Device Specific.(Z5)........22 Device Specific.(Z6)........H17923E Brand.......................XS |
1 2 3 4 5 6 7 8 9 10 | # df Filesystem 512-blocks Free %Used Iused %Iused Mounted on /dev/hd4 360448 84208 77% 9790 48% / /dev/hd2 3309568 298576 91% 30742 47% /usr /dev/hd9var 163840 124448 25% 514 4% /var /dev/hd3 131072 122696 7% 70 1% /tmp /dev/hd1 32768 32064 3% 5 1% /home /dev/hd11admin 262144 261416 1% 5 1% /admin /proc - - - - - /proc/dev/hd10opt 294912 127536 57% 1661 11% /opt |
1 2 3 4 | # df -h Filesystem Size Used Avail Use% Mounted on /dev/sda6 38G 16G 23G 41% / udev 1.5G 96K 1.5G 1% /dev |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 | #du -a 0 ./lost+found 0 ./.oslevel.datafiles/.oslevel.hold 8 ./.oslevel.datafiles/.oslevel.mlinfo.cache 8 ./diagSEgenSnap/general/emgr.snap 2304 ./diagSEgenSnap/general/trcfmt 8 ./diagSEgenSnap/general/inittab 8 ./diagSEgenSnap/general/survdump.settings 4976 ./diagSEgenSnap/general 1448 ./diagSEgenSnap/snapH.pax.Z 6424 ./diagSEgenSnap 8 ./.ctinst.log 0 ./rc.net.serial.out 400 ./lvmt.log … 7344 |
