1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 | import org.apache.spark.ml.Pipeline import org.apache.spark.ml.classification._ import org.apache.spark.ml.evaluation.MulticlassClassificationEvaluator import org.apache.spark.ml.feature.{IndexToString, StringIndexer, VectorAssembler} import org.apache.spark.ml.param.ParamMap import org.apache.spark.sql.SQLContext import org.apache.spark.{SparkConf, SparkContext} object ClassificationPipeline { def main(args: Array[String]) { if (args.length < 1){ println("Usage:ClassificationPipeline inputDataFile") sys.exit(1) } val conf = new SparkConf().setAppName("Classification with ML Pipeline") val sc = new SparkContext(conf) val sqlCtx = new SQLContext(sc) /** Step 1 * Read the source data file and convert it to be a dataframe with columns named. * 3.6216,8.6661,-2.8073,-0.44699,0 * 4.5459,8.1674,-2.4586,-1.4621,0 * 3.866,-2.6383,1.9242,0.10645,0 * 3.4566,9.5228,-4.0112,-3.5944,0 * 0.32924,-4.4552,4.5718,-0.9888,0 * ... ... */ val parsedRDD = sc.textFile(args(0)).map(_.split(",")).map(eachRow => { val a = eachRow.map(x => x.toDouble) (a(0),a(1),a(2),a(3),a(4)) }) val df = sqlCtx.createDataFrame(parsedRDD).toDF( "f0","f1","f2","f3","label").cache() /** * * Step 2 * StringIndexer encodes a string column of labels * to a column of label indices. The indices are in [0, numLabels), * ordered by label frequencies. * This can help detect label in raw data and give it an index automatically. * So that it can be easily processed by existing spark machine learning algorithms. * */ val labelIndexer = new StringIndexer() .setInputCol("label") .setOutputCol("indexedLabel") .fit(df) /** * Step 3 * Define a VectorAssembler transformer to transform source features data to be a vector * This is helpful when raw input data contains non-feature columns, and it is common for * such a input data file to contain columns such as "ID", "Date", etc. */ val vectorAssembler = new VectorAssembler() .setInputCols(Array("f0","f1","f2","f3")) .setOutputCol("featureVector") /** * Step 4 * Create RandomForestClassifier instance and set the input parameters. * Here we will use 5 trees Random Forest to train on input data. */ val rfClassifier = new RandomForestClassifier() .setLabelCol("indexedLabel") .setFeaturesCol("featureVector") .setNumTrees(5) /** * Step 5 * Convert indexed class labels back to original one so that it can be easily understood when we * need to display or save the prediction result to a file. */ val labelConverter = new IndexToString() .setInputCol("prediction") .setOutputCol("predictedLabel") .setLabels(labelIndexer.labels) //Step 6 //Randomly split the input data by 8:2, while 80% is for training, the rest is for testing. val Array(trainingData, testData) = df.randomSplit(Array(0.8, 0.2)) /** * Step 7 * Create a ML pipeline which is constructed by for 4 PipelineStage objects. * and then call fit method to perform defined operations on training data. */ val pipeline = new Pipeline().setStages(Array(labelIndexer,vectorAssembler,rfClassifier,labelConverter)) val model = pipeline.fit(trainingData) /** *Step 8 *Perform predictions about testing data. This transform method will return a result DataFrame *with new prediction column appended towards previous DataFrame. * * */ val predictionResultDF = model.transform(testData) /** * Step 9 * Select features,label,and predicted label from the DataFrame to display. * We only show 20 rows, it is just for reference. */ predictionResultDF.select("f0","f1","f2","f3","label","predictedLabel").show(20) /** * Step 10 * The evaluator code is used to compute the prediction accuracy, this is * usually a valuable feature to estimate prediction accuracy the trained model. */ val evaluator = new MulticlassClassificationEvaluator() .setLabelCol("label") .setPredictionCol("prediction") .setMetricName("precision") val predictionAccuracy = evaluator.evaluate(predictionResultDF) println("Testing Error = " + (1.0 - predictionAccuracy)) /** * Step 11(Optional) * You can choose to print or save the the model structure. */ val randomForestModel = model.stages(2).asInstanceOf[RandomForestClassificationModel] println("Trained Random Forest Model is:\n" + randomForestModel.toDebugString) } } |
