1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 | #!/usr/bin/env bash # The Shell script for setup environment before install spark cluster # # The install steps as below # # 1. vi /etc/sysconfig/network, add the below info into all cluster machines # NETWORKING=yes # HOSTNAME=<machineName> # # 2. vi /etc/ntp.conf, manual setup the information for ntpd # # 3. modify the machineName, master and prefix, we suppose that all the machines with the same prefix # # 4. run the script in master with command ./installsetup.sh # # 预定义说明部分,包含前缀,主机名以及机群机器列表 prefix="c650" master="c6501" machineName=" 192.168.65.101 c6501.ambari.apache.org c6501 192.168.65.102 c6502.ambari.apache.org c6502 192.168.65.103 c6503.ambari.apache.org c6503 " # 文件的限制数量,将被添加到 limits.conf 文件中 numfiles=" root hard nofile 65536 root soft nofile 65536 root hard nproc 65536 root soft nproc 65536 " echo "Begin setup environment" # 添加机器 IP,名称等到 hosts 文件 cat >> /etc/hosts << EOF ${machineName} EOF # add the file limits cat >> /etc/security/limits.conf << EOF ${numfiles} EOF # 添加时间同步信息 cat > /tmp/sync.conf << EOF # Add time sync: */20 * * * * ( /usr/sbin/ntpdate -u $master ) && ( hwclock --systohc ) EOF # 在主机和节点之间配置 SSH 无密码登录 mkdir -p /root/.ssh; chmod 700 /root/.ssh ssh-keygen -t dsa -N '' -f /root/.ssh/id_dsa cp /root/.ssh/id_dsa.pub /root/.ssh/authorized_keys chmod 600 /root/.ssh/authorized_keys nodes=" ` cat /etc/hosts | grep $prefix | awk ' { print $3 } ' ` " echo $nodes for target in $nodes ; do echo "Begin setup machine: " $target "= = = = = = = = = = = = >" ssh -o StrictHostKeyChecking=no $target " setenforce 0 " ssh -o StrictHostKeyChecking=no $target " mkdir -p /root/.ssh ; chmod 700 /root/.ssh " scp /root/.ssh/* $target:/root/.ssh/ # 备份原始的 hosts 信息,最好提前手动备份,以防丢失 echo "Backup original hosts = = = = = = = = = = = = >" scp $target:/etc/hosts $target:/etc/hosts_bak_auto # 拷贝 hosts 文件到机群内所有机器 echo "Copy master hosts to cluster = = = = = = = = = = = = >" scp /etc/hosts $target:/etc/hosts # 禁用 SELINUX echo "Disable SELINUX = = = = = = = = = = = = >" ssh $target "sed s/=enforcing/=disabled/g /etc/selinux/config -i ; grep \"SELINUX=disabled\" /etc/selinux/config" ssh $target " setenforce 0 " echo "SELINUX=disabled" # 关闭 IPv6 echo "Close IPv6 = = = = = = = = = = = = >" ssh $target " echo \" install ipv6 /bin/true \" > /etc/modprobe.d/ipv6off.conf ; cat /etc/modprobe.d/ipv6off.conf " lsmod | grep -i ipv6 ifconfig | grep -i inet6 echo $mod "Above should be empty for IPv6 = = = = = = = = = = = = >" echo $config "Above should be empty for IPv6 = = = = = = = = = = = = >" # 关闭防火墙 firewall echo "Close firewall = = = = = = = = = = = = >" ssh $target "service iptables save" ssh $target "service iptables stop" ssh $target "chkconfig iptables off" ssh $target "sed -i \" /service iptables stop/d \" /etc/rc.local ; echo \ " service iptables stop\ ">> /etc/rc.local " # 关闭 hugepage ssh $target "transparent_hugepage=never" ssh $target "echo never > /sys/kernel/mm/redhat_transparent_hugepage/enabled" ssh $target "echo never > /sys/kernel/mm/redhat_transparent_hugepage/defrag" # 调整并备份 limits.conf,并将修改信息应用到机群内所有机器 echo "Modify the limits to 65536 = = = = = = = = = = = = >" sed -i " /pam_limits/d " /etc/pam.d/login; echo " session required pam_limits.so " >> /etc/pam.d/login echo "Backup original limits.conf = = = = = = = = = = = = >" scp $target:/etc/security/limits.conf $target:/etc/security/limits.conf_bak_auto echo "Copy master limits.conf to cluster = = = = = = = = = = = = >" scp /etc/security/limits.conf $target:/etc/security/limits.conf ssh $target " sed -i \" /pam_limits/d \" /etc/pam.d/login " ssh $target " echo \" session required pam_limits.so\" >> /etc/pam.d/login " #如果存在 dnsmasq,则关闭 echo "Close dnsmasq = = = = = = = = = = = = >" ssh $target " service dnsmasq stop " ssh $target " chkconfig dnsmasq off " # 检查端口是否被占用,此处只列举了部分端口,用户可以自行修改 echo "Check port = = = = = = = = = = = = >" ssh $target " lsof -i:53,1528,2181,2182,7052,7869,7870,7871,7872,7873,7874,7875,7876,7877,7878,7879,7880,7881,7882,7883,8004,8006,8007,8080,8200,8280,8888,9000,9001,9093,9099,9999,10000,10101,10102,14000,18080,50010,50020,50030,50070,50075,50090,60000,60010,60020,60030 " echo "The above port need to be closed if existed" # 同步 ntpd scp /tmp/sync.conf $target:/tmp/sync.conf ssh $target " crontab /tmp/sync.conf ; service crond reload;" ssh $target " /usr/sbin/ntpdate -u " $master ssh $target " crontab -l " ssh $target " service ntpd restart" done # 拷贝 known_hosts 文件到机群所有机器 for target in $nodes ; do scp $target:/root/.ssh/known_hosts $target:/root/.ssh/known_hosts_bak scp /root/.ssh/known_hosts $target:/root/.ssh/ ssh $target " hostname $target " done |
