1 2 3 4 5 6 7 8 9 10 11 | <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/1999/XMLSchema-instance" xmlns:xsd="http://www.w3.org/1999/XMLSchema"> <SOAP-ENV:Header /> <SOAP-ENV:Body> <ns1:getPrice xmlns:ns1="urn:xmethods-BNPriceCheck" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> <isbn xsi:type="xsd:string">0672324229</isbn> </ns1:getPrice> </SOAP-ENV:Body> </SOAP-ENV:Envelope> |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 | import javax.xml.soap.SOAPConnectionFactory; import javax.xml.soap.SOAPConnection; public class SOAPTip { public static void main(String args[]) { try { //First create the connection SOAPConnectionFactory soapConnFactory = SOAPConnectionFactory.newInstance(); SOAPConnection connection = soapConnFactory.createConnection(); //Close the connection connection.close(); } catch(Exception e) { System.out.println(e.getMessage()); } } } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 | import javax.xml.soap.SOAPConnectionFactory; import javax.xml.soap.SOAPConnection; import javax.xml.soap.MessageFactory; import javax.xml.soap.SOAPMessage; import javax.xml.soap.SOAPPart; import javax.xml.soap.SOAPEnvelope; import javax.xml.soap.SOAPBody; public class SOAPTip { public static void main(String args[]) { try { //First create the connection SOAPConnectionFactory soapConnFactory = SOAPConnectionFactory.newInstance(); SOAPConnection connection = soapConnFactory.createConnection(); //Next, create the actual message MessageFactory messageFactory = MessageFactory.newInstance(); SOAPMessage message = messageFactory.createMessage(); //Create objects for the message parts SOAPPart soapPart = message.getSOAPPart(); SOAPEnvelope envelope = soapPart.getEnvelope(); SOAPBody body = envelope.getBody(); //Close the connection connection.close(); } catch(Exception e) { System.out.println(e.getMessage()); } } } |
