1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 | ... import javax.xml.soap.SOAPBody; import javax.xml.soap.SOAPElement; public class SOAPTip { public static void main(String args[]) { try { ... //Create objects for the message parts SOAPPart soapPart = message.getSOAPPart(); SOAPEnvelope envelope = soapPart.getEnvelope(); SOAPBody body = envelope.getBody(); //Populate the body //Create the main element and namespace SOAPElement bodyElement = body.addChildElement(envelope.createName("getPrice" , "ns1", "urn:xmethods-BNPriceCheck")); //Add content bodyElement.addChildElement("isbn").addTextNode("0672324229"); //Save the message message.saveChanges(); //Check the input System.out.println("\\nREQUEST:\\n"); message.writeTo(System.out); System.out.println(); //Close the connection connection.close(); } catch(Exception e) { System.out.println(e.getMessage()); } } } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 | ... import javax.xml.soap.SOAPElement; import java.io.FileInputStream; import javax.xml.transform.stream.StreamSource; public class SOAPTip { public static void main(String args[]) { ... //Create objects for the message parts SOAPPart soapPart = message.getSOAPPart(); SOAPEnvelope envelope = soapPart.getEnvelope(); SOAPBody body = envelope.getBody(); //Populate the Message StreamSource preppedMsgSrc = new StreamSource( new FileInputStream("prepped.msg")); soapPart.setContent(preppedMsgSrc); //Save the message message.saveChanges(); ... } } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 | ... public class SOAPTip { public static void main(String args[]) { ... //Check the input System.out.println("\\nREQUEST:\\n"); message.writeTo(System.out); System.out.println(); //Send the message and get a reply //Set the destination String destination = "http://services.xmethods.net:80/soap/servlet/rpcrouter"; //Send the message SOAPMessage reply = connection.call(message, destination); //Close the connection connection.close(); ... } } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 | ... import javax.xml.transform.TransformerFactory; import javax.xml.transform.Transformer; import javax.xml.transform.Source; import javax.xml.transform.stream.StreamResult; public class SOAPTip { public static void main(String args[]) { try { ... //Send the message SOAPMessage reply = connection.call(message, destination); //Check the output System.out.println("\\nRESPONSE:\\n"); //Create the transformer TransformerFactory transformerFactory = TransformerFactory.newInstance(); Transformer transformer = transformerFactory.newTransformer(); //Extract the content of the reply Source sourceContent = reply.getSOAPPart().getContent(); //Set the output for the transformation StreamResult result = new StreamResult(System.out); transformer.transform(sourceContent, result); System.out.println(); //Close the connection connection.close(); ... } } |
