1 2 3 4 5 6 7 8 9 10 11 12 | <!-- Action Servlet Configuration --> <servlet> <servlet-name>action</servlet-name> <servlet-class>org.apache.struts.action.ActionServlet</servlet-class> <init-param> <param-name>config</param-name> <param-value> /WEB-INF/struts-config.xml, /WEB-INF/struts-config-registration.xml </param-value> </init-param> <load-on-startup>1</load-on-startup> </servlet> |
1 2 3 4 5 6 7 8 9 10 11 12 | <init-param> <param-name>config</param-name> <param-value>/WEB-INF/struts-config.xml</param-value> </init-param> <init-param> <param-name>config/customer</param-name> <param-value>/WEB-INF/struts-config-customer.xml</param-value> </init-param> <init-param> <param-name>config/order</param-name> <param-value>/WEB-INF/struts-config-order.xml</param-value> </init-param> |
1 2 3 4 5 6 7 8 9 10 11 12 | ... <struts-config> ... <global-forwards> <forward name="toModuleB" contextRelative="true" path="/moduleB/index.do" redirect="true"/> ... </global-forwards> ... </struts-config> |
1 2 3 4 5 6 7 8 9 10 11 | <action-mappings> <!-- Action mapping for profile form --> <action path="/login" type="com.ncu.test.LoginAction" name="loginForm" scope="request" input="tile.userLogin" validate="true"> <forward name="success" contextRelative="true" path="/moduleA/login.do"/> </action> </action-mappings> |
1 | <forward name="success" contextRelative="true" path="/login.do"/> |
1 2 3 4 5 6 7 | ... <action-mappings> <action path="/toModule" type="org.apache.struts.actions.SwitchAction"/> ... </action-mappings> ... |
