1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 | echo off setlocal set ECLIPSE="D:\Program Files\IBM\SDP70" set WORKSPACE=D:\MyWorkspaceANT set BUILDFILE=D:\Customer.xml set JAVA_HOME=%ECLIPSE%\jdk set PATH=%JAVA_HOME%\bin;%PATH% set CLASSPATH=%JAVA_HOME%\lib;%CLASSPATH% java -cp %ECLIPSE%\startup.jar org.eclipse.core.launcher.Main -clean -data %WORKSPACE% -application org.eclipse.Ant.core.antRunner -buildfile %BUILDFILE% Where: ECLIPSE environment variable defines the path to the eclipse folder within RAD WORKSPACE defines the path where the workspace will be created BUILDFILE is the path to your generated Ant script you would like to run. |
