1 2 3 | set-variable=max_connections=500 set-variable=wait_timeout=10 max_connect_errors = 100 |
1 2 3 4 5 6 7 8 | mysql> SHOW STATUS LIKE 'open%tables'; +---------------+-------+ | Variable_name | Value | +---------------+-------+ | Open_tables | 5000 | | Opened_tables | 195 | +---------------+-------+ 2 rows in set (0.00 sec) |
1 2 3 4 5 6 7 8 9 10 | mysql> SHOW STATUS LIKE 'threads%'; +-------------------+--------+ | Variable_name | Value | +-------------------+--------+ | Threads_cached | 27 | | Threads_connected | 15 | | Threads_created | 838610 | | Threads_running | 3 | +-------------------+--------+ 4 rows in set (0.00 sec) |
1 2 3 4 5 6 7 8 | mysql> show status like '%key_read%'; +-------------------+-----------+ | Variable_name | Value | +-------------------+-----------+ | Key_read_requests | 163554268 | | Key_reads | 98247 | +-------------------+-----------+ 2 rows in set (0.00 sec) |
1 2 3 4 5 6 7 8 9 | mysql> SHOW STATUS LIKE 'created_tmp%'; +-------------------------+-------+ | Variable_name | Value | +-------------------------+-------+ | Created_tmp_disk_tables | 30660 | | Created_tmp_files | 2 | | Created_tmp_tables | 32912 | +-------------------------+-------+ 3 rows in set (0.00 sec) |
1 2 3 4 5 6 7 8 9 10 | mysql> SHOW STATUS LIKE "sort%"; +-------------------+---------+ | Variable_name | Value | +-------------------+---------+ | Sort_merge_passes | 1 | | Sort_range | 79192 | | Sort_rows | 2066532 | | Sort_scan | 44006 | +-------------------+---------+ 4 rows in set (0.00 sec) |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 | mysql> SHOW STATUS LIKE "com_select"; +---------------+--------+ | Variable_name | Value | +---------------+--------+ | Com_select | 318243 | +---------------+--------+ 1 row in set (0.00 sec) mysql> SHOW STATUS LIKE "handler_read_rnd_next"; +-----------------------+-----------+ | Variable_name | Value | +-----------------------+-----------+ | Handler_read_rnd_next | 165959471 | +-----------------------+-----------+ 1 row in set (0.00 sec) |
