1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 | <?php require_once("xml2json.php"); <br> // Filename from where XML contents are to be read. $testXmlFile = ""; <br> // Read the filename from the command line. if ($argc <= 1) { print("Please provide the XML filename as a command-line argument:\n"); print("\tphp -f xml2json_test.php test1.xml\n"); return; } else { $testXmlFile = $argv[1]; } <br> //Read the XML contents from the input file. file_exists($testXmlFile) or die('Could not find file ' . $testXmlFile); $xmlStringContents = file_get_contents($testXmlFile); <br> $jsonContents = ""; // Convert it to JSON now. // xml2json simply takes a String containing XML contents as input. $jsonContents = xml2json::transformXmlStringToJson($xmlStringContents); <br> echo("JSON formatted output generated by xml2json:\n\n"); echo($jsonContents); ?> |
1 | php -f xml2json_test.php test2.xml |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 | <?xml version="1.0" encoding="UTF-8"?> <books> <book id="1"> <title>Code Generation in Action</title> <author><first>Jack</first><last>Herrington</last></author> <publisher>Manning</publisher> </book> <br> <book id="2"> <title>PHP Hacks</title> <author><first>Jack</first><last>Herrington</last></author> <publisher>O'Reilly</publisher> </book> <br> <book id="3"> <title>Podcasting Hacks</title> <author><first>Jack</first><last>Herrington</last></author> <publisher>O'Reilly</publisher> </book> </books> |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 | { "books" : { "book" : [ { "@attributes" : { "id" : "1" }, "title" : "Code Generation in Action", "author" : { "first" : "Jack", "last" : "Herrington" }, "publisher" : "Manning" }, { "@attributes" : { "id" : "2" }, "title" : "PHP Hacks", "author" : { "first" : "Jack", "last" : "Herrington" }, "publisher" : "O'Reilly" }, { "@attributes" : { "id" : "3" }, "title" : "Podcasting Hacks", "author" : { "first" : "Jack", "last" : "Herrington" }, "publisher" : "O'Reilly" } ]} } |
