1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 | package com.baobaotao.io; import java.io.IOException; import java.io.InputStream; import org.springframework.core.io.ClassPathResource; import org.springframework.core.io.FileSystemResource; import org.springframework.core.io.Resource; public class FileSourceExample { public static void main(String[] args) { try { String filePath = "D:/masterSpring/chapter23/webapp/WEB-INF/classes/conf/file1.txt"; // ① 使用系统文件路径方式加载文件 Resource res1 = new FileSystemResource(filePath); // ② 使用类路径方式加载文件 Resource res2 = new ClassPathResource("conf/file1.txt"); InputStream ins1 = res1.getInputStream(); InputStream ins2 = res2.getInputStream(); System.out.println("res1:"+res1.getFilename()); System.out.println("res2:"+res2.getFilename()); } catch (IOException e) { e.printStackTrace(); } } } |
1 2 3 4 5 6 7 8 9 10 | <%@ page language="java" contentType="text/html; charset=utf-8" pageEncoding="utf-8"%> <jsp:directive.page import=" org.springframework.web.context.support.ServletContextResource"/> <jsp:directive.page import="org.springframework.core.io.Resource"/> <% // ① 注意文件资源地址以相对于 Web 应用根路径的方式表示 Resource res3 = new ServletContextResource(application, "/WEB-INF/classes/conf/file1.txt"); out.print(res3.getFilename()); %> |
1 2 3 4 5 6 7 8 9 10 11 12 13 | package com.baobaotao.io; import java.io.File; import org.springframework.util.ResourceUtils; public class ResourceUtilsExample { public static void main(String[] args) throws Throwable{ File clsFile = ResourceUtils.getFile("classpath:conf/file1.txt"); System.out.println(clsFile.isFile()); String httpFilePath = "file:/masterSpring/chapter23/src/conf/file1.txt"; File httpFile = ResourceUtils.getFile(httpFilePath); System.out.println(httpFile.isFile()); } } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 | package com.baobaotao.io; import java.util.Locale; import org.springframework.core.io.Resource; import org.springframework.core.io.support.LocalizedResourceHelper; public class LocaleResourceTest { public static void main(String[] args) { LocalizedResourceHelper lrHalper = new LocalizedResourceHelper(); // ① 获取对应美国的本地化文件资源 Resource msg_us = lrHalper.findLocalizedResource("i18n/message", ".properties", Locale.US); // ② 获取对应中国大陆的本地化文件资源 Resource msg_cn = lrHalper.findLocalizedResource("i18n/message", ".properties", Locale.CHINA); System.out.println("fileName(us):"+msg_us.getFilename()); System.out.println("fileName(cn):"+msg_cn.getFilename()); } } |
