1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 | package com.tedneward.scitter { import org.apache.commons.httpclient._, auth._, methods._, params._ import scala.xml._ /** * Status message type. This will typically be the most common message type * sent back from Twitter (usually in some kind of collection form). Note * that all optional elements in the Status type are represented by the * Scala Option[T] type, since that's what it's there for. */ abstract class Status { /** * Nested User type. This could be combined with the top-level User type, * if we decide later that it's OK for this to have a boatload of optional * elements, including the most-recently-posted status update (which is a * tad circular). */ abstract class User { val id : Long val name : String val screenName : String val description : String val location : String val profileImageUrl : String val url : String val protectedUpdates : Boolean val followersCount : Int } /** * Object wrapper for transforming (format) into User instances. */ object User { /* def fromAtom(node : Node) : Status = { } */ /* def fromRss(node : Node) : Status = { } */ def fromXml(node : Node) : User = { new User { val id = (node \ "id").text.toLong val name = (node \ "name").text val screenName = (node \ "screen_name").text val description = (node \ "description").text val location = (node \ "location").text val profileImageUrl = (node \ "profile_image_url").text val url = (node \ "url").text val protectedUpdates = (node \ "protected").text.toBoolean val followersCount = (node \ "followers_count").text.toInt } } } val createdAt : String val id : Long val text : String val source : String val truncated : Boolean val inReplyToStatusId : Option[Long] val inReplyToUserId : Option[Long] val favorited : Boolean val user : User } /** * Object wrapper for transforming (format) into Status instances. */ object Status { /* def fromAtom(node : Node) : Status = { } */ /* def fromRss(node : Node) : Status = { } */ def fromXml(node : Node) : Status = { new Status { val createdAt = (node \ "created_at").text val id = (node \ "id").text.toLong val text = (node \ "text").text val source = (node \ "source").text val truncated = (node \ "truncated").text.toBoolean val inReplyToStatusId = if ((node \ "in_reply_to_status_id").text != "") Some((node \"in_reply_to_status_id").text.toLong) else None val inReplyToUserId = if ((node \ "in_reply_to_user_id").text != "") Some((node \"in_reply_to_user_id").text.toLong) else None val favorited = (node \ "favorited").text.toBoolean val user = User.fromXml((node \ "user")(0)) } } } /** * Object for consuming "non-specific" Twitter feeds, such as the public timeline. * Use this to do non-authenticated requests of Twitter feeds. */ object Scitter { /** * Ping the server to see if it's up and running. * * Twitter docs say: * test * Returns the string "ok" in the requested format with a 200 OK HTTP status code. * URL: http://twitter.com/help/test.format * Formats: xml, json * Method(s): GET */ def test : Boolean = { val client = new HttpClient() val method = new GetMethod("http://twitter.com/help/test.xml") method.getParams().setParameter(HttpMethodParams.RETRY_HANDLER, new DefaultHttpMethodRetryHandler(3, false)) client.executeMethod(method) val statusLine = method.getStatusLine() statusLine.getStatusCode() == 200 } /** * Query the public timeline for the most recent statuses. * * Twitter docs say: * public_timeline * Returns the 20 most recent statuses from non-protected users who have set * a custom user icon. Does not require authentication. Note that the * public timeline is cached for 60 seconds so requesting it more often than * that is a waste of resources. * URL: http://twitter.com/statuses/public_timeline.format * Formats: xml, json, rss, atom * Method(s): GET * API limit: Not applicable * Returns: list of status elements */ def publicTimeline : List[Status] = { import scala.collection.mutable.ListBuffer val client = new HttpClient() val method = new GetMethod("http://twitter.com/statuses/public_timeline.xml") method.getParams().setParameter(HttpMethodParams.RETRY_HANDLER, new DefaultHttpMethodRetryHandler(3, false)) client.executeMethod(method) val statusLine = method.getStatusLine() if (statusLine.getStatusCode() == 200) { val responseXML = XML.loadString(method.getResponseBodyAsString()) val statusListBuffer = new ListBuffer[Status] for (n <- (responseXML \\ "status").elements) statusListBuffer += (Status.fromXml(n)) statusListBuffer.toList } else { Nil } } } /** * Class for consuming "authenticated user" Twitter APIs. Each instance is * thus "tied" to a particular authenticated user on Twitter, and will * behave accordingly (according to the Twitter API documentation). */ class Scitter(username : String, password : String) { /** * Verify the user credentials against Twitter. * * Twitter docs say: * verify_credentials * Returns an HTTP 200 OK response code and a representation of the * requesting user if authentication was successful; returns a 401 status * code and an error message if not. Use this method to test if supplied * user credentials are valid. * URL: http://twitter.com/account/verify_credentials.format * Formats: xml, json * Method(s): GET */ def verifyCredentials : Boolean = { val client = new HttpClient() val method = new GetMethod("http://twitter.com/help/test.xml") method.getParams().setParameter(HttpMethodParams.RETRY_HANDLER, new DefaultHttpMethodRetryHandler(3, false)) client.getParams().setAuthenticationPreemptive(true) val creds = new UsernamePasswordCredentials(username, password) client.getState().setCredentials( new AuthScope("twitter.com", 80, AuthScope.ANY_REALM), creds) client.executeMethod(method) val statusLine = method.getStatusLine() statusLine.getStatusCode() == 200 } } } |
