1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 | ... <xs:element name="CustomDialog"> <xs:complexType> <xs:sequence> <xs:element ref="xui:GridLayout"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xuianel"/> </xs:sequence> <xs:attribute name="modal" type="xs:boolean" use="required"/> <xs:attribute name="idref" type="xs:IDREF" use="optional"/> <xs:attribute name="name" type="xs:string" use="required"/> <xs:attribute name="id" type="xs:ID" use="required"/> <xs:attribute name="x" type="xs:short" use="required"/> <xs:attribute name="y" type="xs:short" use="required"/> <xs:attribute name="width" type="xs:unsignedShort" use="required"/> <xs:attribute name="height" type="xs:unsignedShort" use="required"/> <xs:attribute name="visible" type="xs:boolean" use="required"/> </xs:complexType> </xs:element> <xs:element name="anel"> <xs:complexType> <xs:sequence> <xs:element maxOccurs="1" minOccurs="1" ref="xui:GridLayout"/> <xs:choice minOccurs="0" maxOccurs="unbounded"> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xui:Button"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xui:Calendar"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xui:CheckBox"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xui:ComboBox"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xui:HypertextPane"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xui:Image"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xuiabel"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xuiist"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xuiasswordField"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xuirogressBar"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xui:RadioButton"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xui:SliderBar"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xui:Table"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xui:TextArea"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xui:TextField"/> <xs:element minOccurs="0" maxOccurs="unbounded" ref="xui:Tree"/> </xs:choice> </xs:sequence> <xs:attribute name="x" type="xs:unsignedShort" use="required"/> <xs:attribute name="y" type="xs:unsignedShort" use="required"/> <xs:attribute name="width" type="xs:unsignedShort" use="required"/> <xs:attribute name="height" type="xs:unsignedShort" use="required"/> <xs:attribute name="name" type="xs:string" use="required"/> <xs:attribute name="id" type="xs:ID" use="required"/> <xs:attribute name="idref" type="xs:IDREF" use="optional"/> </xs:complexType> </xs:element> <xs:element name="RadioButton"> <xs:complexType> <xs:sequence> <xs:element maxOccurs="3" minOccurs="0" ref="xui:Image"/> </xs:sequence> <xs:attribute name="label" type="xs:string" use="required"/> <xs:attribute name="x" type="xs:unsignedShort" use="required"/> <xs:attribute name="y" type="xs:unsignedShort" use="required"/> <xs:attribute name="width" type="xs:unsignedShort" use="required"/> <xs:attribute name="height" type="xs:unsignedShort" use="required"/> <xs:attribute name="enabled" type="xs:boolean" use="required"/> <xs:attribute name="selected" type="xs:boolean" use="required"/> <xs:attribute name="id" type="xs:ID" use="required"/> <xs:attribute name="orientation" use="required"> <xs:simpleType> <xs:restriction base="xs:token"> <xs:enumeration value="horizontal"/> <xs:enumeration value="vertical"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> ... |
