1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 | <div dojoType="dijit.Menu" id="menu_context_3" contextMenuForWindow="true" style="display: none;"> <!-- 增加图标效果和快捷键 --> <div dojoType="dijit.MenuItem" iconClass="dijitEditorIcon dijitEditorIconCut" onClick="console.log('nothing will happen,but you can implement it!')" accelKey="Ctrl+X">Cut</div> <div dojoType="dijit.MenuItem" iconClass="dijitEditorIcon dijitEditorIconCopy" onClick="console.log('nothing will happen,but you can implement it!')" accelKey="Ctrl+C">Copy</div> <!-- 禁用该菜单项 --> <div dojoType="dijit.MenuItem" iconClass="dijitEditorIcon dijitEditorIconPaste" onClick="console.log('nothing will happen,but you can implement it!')" disabled="true" accelKey="Ctrl+V">Paste</div> <div dojoType="dijit.MenuSeparator"></div> <!-- 弹出子菜单 --> <div dojoType="dijit.PopupMenuItem" id="popupMenuItem"> <span>Popup Menu</span> <div dojoType="dijit.Menu" id="submenu"> <div dojoType="dijit.MenuItem" id="submenu_item1" onClick="console.log('submenu_item1')">Submenu Item 1</div> <div dojoType="dijit.MenuItem" id="submenu_item2" onClick="console.log('submenu_item2')">Submenu Item 2</div> <div dojoType="dijit.PopupMenuItem" id="submenu_item3"> <span>Deeper Popup Menu Item</span> <div dojoType="dijit.Menu" id="submenu_item3submenu"> <div dojoType="dijit.MenuItem" onClick="console.log(' submenu_item3submenu_item1!')">Submenu Submenu Item 1</div> <div dojoType="dijit.MenuItem" onClick="console.log(' submenu_item3submenu_item2!')">Submenu Submenu Item 2</div> </div> </div> </div> </div> <!-- 弹出其他 Widget --> <div dojoType="dijit.PopupMenuItem"> <span>Different Popup</span> <div dojoType="dijit.ColorPalette"></div> </div> <div dojoType="dijit.MenuSeparator"></div> <!-- 复选菜单项 --> <div dojoType="dijit.CheckedMenuItem" checked="true" onChange="if(arguments[0]) console.log('checked'); else console.log('unchecked');"> Checked </div> </div> |
1 2 3 4 5 6 7 8 | <div dojoType="dijit.PopupMenuItem" id="popupMenuItem"> <span>Popup Menu</span> <div dojoType="dijit.Menu" id="submenu"> <div dojoType="dijit.MenuItem" id="submenu_item1"> Submenu Item 1 </div> ... </div> |
