1 | c2b[c2bIndex[char >> 8] + (char & 0xff)] |
1 2 3 4 5 6 7 8 9 10 | if (bb > 0xff) { // DoubleByte if (dl - dp < 2) return CoderResult.OVERFLOW; da[dp++] = (byte) (bb >> 8); da[dp++] = (byte) bb; } else { // SingleByte if (dl - dp < 1) return CoderResult.OVERFLOW; da[dp++] = (byte) bb; } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 | private CoderResult encodeArrayLoop(CharBuffer src, ByteBuffer dst){ char[] sa = src.array(); int sp = src.arrayOffset() + src.position(); int sl = src.arrayOffset() + src.limit(); byte[] da = dst.array(); int dp = dst.arrayOffset() + dst.position(); int dl = dst.arrayOffset() + dst.limit(); int dlASCII = dp + Math.min(sl - sp, dl - dp); // ASCII only loop while (dp < dlASCII && sa[sp] < '\u0080') da[dp++] = (byte) sa[sp++]; while (sp < sl) { char c = sa[sp]; if (c < 0x80) { // Have at most seven bits if (dp >= dl) return overflow(src, sp, dst, dp); da[dp++] = (byte)c; } else if (c < 0x800) { // 2 bytes, 11 bits if (dl - dp < 2) return overflow(src, sp, dst, dp); da[dp++] = (byte)(0xc0 | (c >> 6)); da[dp++] = (byte)(0x80 | (c & 0x3f)); } else if (Character.isSurrogate(c)) { // Have a surrogate pair if (sgp == null) sgp = new Surrogate.Parser(); int uc = sgp.parse(c, sa, sp, sl); if (uc < 0) { updatePositions(src, sp, dst, dp); return sgp.error(); } if (dl - dp < 4) return overflow(src, sp, dst, dp); da[dp++] = (byte)(0xf0 | ((uc >> 18))); da[dp++] = (byte)(0x80 | ((uc >> 12) & 0x3f)); da[dp++] = (byte)(0x80 | ((uc >> 6) & 0x3f)); da[dp++] = (byte)(0x80 | (uc & 0x3f)); sp++; // 2 chars } else { // 3 bytes, 16 bits if (dl - dp < 3) return overflow(src, sp, dst, dp); da[dp++] = (byte)(0xe0 | ((c >> 12))); da[dp++] = (byte)(0x80 | ((c >> 6) & 0x3f)); da[dp++] = (byte)(0x80 | (c & 0x3f)); } sp++; } updatePositions(src, sp, dst, dp); return CoderResult.UNDERFLOW; } |
