1 2 3 4 5 6 7 | // 初始化,加载资源 public void init(FilterConfig filterConfig) throws ServletException // 销毁,回收资源 public void destroy() // 过滤 public void doFilter(ServletRequest req, ServletResponse res, FilterChain chain) throws IOException, ServletException |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 | public void init(FilterConfig filterConfig) throws ServletException { try { this.filterConfig = filterConfig; // 初始化日志器 initLogging(); dispatcher = createDispatcher(filterConfig); dispatcher.init(); dispatcher.getContainer().inject(this); staticResourceLoader.setHostConfig(new FilterHostConfig(filterConfig)); } finally { ActionContext.setContext(null); } } |
1 2 3 4 5 6 7 8 9 10 11 | public void destroy() { if (dispatcher == null) { log.warn("something is seriously wrong, Dispatcher is not initialized (null) "); } else { try { dispatcher.cleanup(); } finally { ActionContext.setContext(null); } } } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 | public void doFilter(ServletRequest req, ServletResponse res, FilterChain chain) throws IOException, ServletException { HttpServletRequest request = (HttpServletRequest) req; HttpServletResponse response = (HttpServletResponse) res; ServletContext servletContext = getServletContext(); String timerKey = "FilterDispatcher_doFilter: "; try { //1 处理前的准备 //1.1 创建值栈对象,值栈包含 object stack 和 context map 两个部分。 ValueStack stack = dispatcher.getContainer().getInstance(ValueStackFactory.class).createValueStack(); //1.2 创建 actionContext。 ActionContext ctx = new ActionContext(stack.getContext()); ActionContext.setContext(ctx); UtilTimerStack.push(timerKey); //1.3 准备和包装 request request = prepareDispatcherAndWrapRequest(request, response); ActionMapping mapping; //2 根据请求路径查找 actionMapping try { mapping = actionMapper.getMapping(request, dispatcher.getConfigurationManager()); } catch (Exception ex) { log.error("error getting ActionMapping", ex); dispatcher.sendError(request, response, servletContext, HttpServletResponse.SC_INTERNAL_SERVER_ERROR, ex); return; } //3 当请求路径没有对应的 actionMapping,走第 2 和第 3 个出口 if (mapping == null) { String resourcePath = RequestUtils.getServletPath(request); if ("".equals(resourcePath) && null != request.getPathInfo()) { resourcePath = request.getPathInfo(); } if (staticResourceLoader.canHandle(resourcePath)) { staticResourceLoader.findStaticResource(resourcePath, request, response); } else { chain.doFilter(request, response); } // 如果是第 2 和第 3 个出口 ,action 的处理到此结束。 return; } //3.1 路径 1,委托 dispatcher 的 serviceAction 进行处理 dispatcher.serviceAction(request, response, servletContext, mapping); } finally { try { //4 清除 ActionContext ActionContextCleanUp.cleanUp(req); } finally { UtilTimerStack.pop(timerKey); } } } |
