1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 | 1.public void setUp() throws Exception { 2. //driver = new HtmlUnitDriver(); 3. driver = new FirefoxDriver(); 4. baseUrl = "http://www.baidu.com/"; 5. driver.manage().timeouts().implicitlyWait(30, TimeUnit.SECONDS); 6.} 7. 8.@Test 9.public void testDemo() throws Exception { 10. driver.get(baseUrl + "/"); 11. driver.findElement(By.id("kw")).clear(); 12. driver.findElement(By.id("kw")).sendKeys("百度翻译"); 13. driver.findElement(By.id("su")).click(); 14. 15. WebElement element; 16. element = driver.findElement(By.id( "op_tran_text" )); 17. //element = driver.findElement(By.xpath( "//textarea[@id= ’ op_tran_text ’ ]" )); 18. element.clear(); 19. element.sendKeys("自动化测试"); 20. 21. WebElement select = driver.findElement(By.xpath( "//select" )); 22. List<WebElement> allOptions = select.findElements(By.tagName( "option" )); 23. for (WebElement option : allOptions) { 24. System.out.println(String.format( "Value is: %s" , \ option.getAttribute("value"))); 25. if(option.getText().equals("zh2en")) 26. option.click(); 27. } 28. 29. driver.findElement(By.xpath("//a[@class='op_tran_btn OP_LOG_BTN']")).click(); 30. 31.driver.switchTo().window( "百度在线翻译" ); 32.} |
1 | WebDriver driver = new HtmlFirefoxDriver(); |
1 | driver.get(baseUrl + "/"); |
1 2 3 4 5 6 7 8 9 10 11 | <input type= "text" name= "passwd" id= "passwd-id" /> WebElement element; element = driver.findElement(By.id( "passwd-id" )); element = driver.findElement(By.name( "passwd" )); element = driver.findElement(By.xpath( "//input[@id= ’ passwd-id ’ ]" )); //XPATH 返回第一个匹配到的元素,如果没有匹配到,抛出 NoSuchElementException element.sendKeys( "some text" ); element.sendKeys( " and some" , Keys.ARROW_DOWN); // 按向下箭头 ; 任何页面元素都可以调用 sendKeys, //例如可以测试一些快捷方式键,键盘的每次输入都是附加在文本串的后面; element.clear(); // 清除文本域内容 |
1 2 3 4 5 6 | WebElement select = driver.findElement(By.xpath( "//select" )); List<WebElement> allOptions = select.findElements(By.tagName("option" )); for(WebElement option : allOptions) { System.out.println(String.format( "Value is: %s" , option.getValue())); option.setSelected(); } |
1 2 3 | Select select = new Select(driver.findElement(By.xpath( "//select" ))); select.deselectAll(); select.selectByVisibleText("Edam"); |
1 2 | driver.findElement(By.id( "submit" )).click(); element.submit();// 要求 element 必须在表单中,否则抛出 NoSuchElementException |
1 2 | WebElement plain = driver.findElement(By.name( "q" )); RenderedWebElement element = (RenderedWebElement) element;// 例如 HtmlUnit Driver 就无法显示出内容 |
1 2 3 4 5 | RenderedWebElement element = (RenderedWebElement) driver.findElement(\ By.name( "source" )); RenderedWebElement target = (RenderedWebElement) driver.findElement(\ By.name( "target" )); element.dragAndDropOn(target); |
1 | driver.switchTo().window( "windowName" ); // 可以通过 js 或者打开窗口的链接获取窗口名称 |
1 2 3 | for (String handle : driver.getWindowHandles()) { driver.switchTo().window(handle); } |
1 2 3 4 | driver.switchTo().frame( "frameName" ); 通过索引访问 subframe: driver.switchTo().frame( "frameName.0.child" );//frameName 的第一个 subframe //的明价 child 的 frame |
1 | Alert alert = driver.switchTo().alert(); |
1 | driver.navigate().to( "http://www.example.com" ); |
1 2 | driver.navigate().forward(); driver.navigate().back(); |
