1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 | repositories { } dependencies { compile project(':demo-model') compile project(':demo-util') compile('org.springframework.boot:spring-boot-starter-aop') compile('org.springframework.cloud:spring-cloud-starter-sleuth') compile('org.springframework.cloud:spring-cloud-sleuth-stream') compile('org.springframework.cloud:spring-cloud-starter-stream-kafka') compile('org.springframework.boot:spring-boot-starter-data-redis') compile('org.springframework.kafka:spring-kafka') compile('org.springframework.boot:spring-boot-starter-web') compile('org.springframework.cloud:spring-cloud-sleuth-zipkin') } |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 | @Pointcut("execution(* onMessage(..)) & & target(org.springframework.data.redis.connection.MessageListener)") public void messageListener() { // This func is intentionally empty. Nothing special is needed here. } @Around("messageListener()") public void interceptMessage(ProceedingJoinPoint joinPoint) throws Throwable { try { Object[] joinPointArgs = joinPoint.getArgs(); Object[] result = new Object[joinPointArgs.length]; for (int i = 0; i < joinPointArgs.length; i++) { Object object = joinPointArgs; ObjectMapper objectMapper = new ObjectMapper(); if (object instanceof Message && jsonParse(object)) { Message message = (Message) object; RedisMessage redisMessage = objectMapper.readValue((String) object.toString(), RedisMessage.class); logger.debug("Received >> redisMessage {} ", redisMessage); Map<String, String> spanMap = redisMessage.getHeader(); String traceIdString = Span.idToHex(Long.parseLong(spanMap.get(TraceMessageHeaders.TRACE_ID_NAME))); String spanId = Span.idToHex(Long.parseLong(spanMap.get(TraceMessageHeaders.SPAN_ID_NAME))); Span parentSpan = SleuthHelper.fromMap(spanMap); logger.debug("Received >> trace {} span {}", traceIdString, spanId); if (sleuthProperties != null && sleuthProperties.isSupportsJoin()) { SleuthHelper.joinSpan(tracer, spanMap); logger.debug("Join trace span {}", spanMap); } else { SleuthHelper.continueSpan(tracer, spanMap); logger.debug("Continue trace span {}", spanMap); } slf4jSpanLogger.logStartedSpan(parentSpan, tracer.getCurrentSpan()); logger.debug("Received >> trace {} span {}", Span.idToHex(tracer.getCurrentSpan().getTraceId()), Span.idToHex(tracer.getCurrentSpan().getSpanId())); byte[] channel = message.getChannel(); byte[] body = SerializationUtils.serialize(redisMessage.getMessage()); logger.debug("Received >> message {}", SerializationUtils.deserialize(body)); result = new RedisDefaultMessage(channel, body); } else { result = object; } } SpanBuilder spanBuilder = Span.builder().from(this.tracer.getCurrentSpan()); Span currentSpan = spanBuilder.parents(this.tracer.getCurrentSpan().getParents()).name(joinPoint.getSi gnature().getName()).remote(false).build(); currentSpan.logEvent("sr"); this.tracer.close(currentSpan); this.tracer.continueSpan(currentSpan); joinPoint.proceed(result); } catch (JsonParseException e) { logger.error("Join trace span with JsonParseException {} ", e); } catch (JsonMappingException e) { logger.error("Join trace span with JsonMappingException {} ", e); } catch (IOException e) { logger.error("Join trace span with IOException {}", e); } } private boolean jsonParse(Object object) { boolean falg = true; ObjectMapper objectMapper = new ObjectMapper(); try { objectMapper.readValue((String) object.toString(), RedisMessage.class); falg = true; } catch (Exception e) { falg = false; } return falg; } |
