并发写操作在 ConcurrentHashMap 中,当执行 put 方法的时候,会需要加锁来完成。我们通过代码来解释一下具体过程: 当我们 new 一个 ConcurrentHashMap 对象,并且执行put操作的时候,首先会执行 ConcurrentHashMap 类中的 put 方法,该方法源码为:
[url=][/url]
/** * Maps the specified key to the specified value in this table. * Neither the key nor the value can be null. * * <p> The value can be retrieved by calling the <tt>get</tt> method * with a key that is equal to the original key. * * @param key key with which the specified value is to be associated * @param value value to be associated with the specified key * @return the previous value associated with <tt>key</tt>, or * <tt>null</tt> if there was no mapping for <tt>key</tt> * @throws NullPointerException if the specified key or value is null */ @SuppressWarnings("unchecked") public V put(K key, V value) { Segment<K,V> s; if (value == null) throw new NullPointerException(); int hash = hash(key); int j = (hash >>> segmentShift) & segmentMask; if ((s = (Segment<K,V>)UNSAFE.getObject // nonvolatile; recheck (segments, (j << SSHIFT) + SBASE)) == null) // in ensureSegment s = ensureSegment(j); return s.put(key, hash, value, false); }[url=][/url]
我们通过注释可以了解到,ConcurrentHashMap 不允许空值。该方法首先有一个 Segment 的引用 s,然后会通过 hash() 方法对 key 进行计算,得到哈希值;继而通过调用 Segment 的 put(K key, int hash, V value, boolean onlyIfAbsent)方法进行存储操作。该方法源码为:
[url=][/url]
final V put(K key, int hash, V value, boolean onlyIfAbsent) { //加锁,这里是锁定的Segment而不是整个ConcurrentHashMap HashEntry<K,V> node = tryLock() ? null :scanAndLockForPut(key, hash, value); V oldValue; try { HashEntry<K,V>[] tab = table; //得到hash对应的table中的索引index int index = (tab.length - 1) & hash; //找到hash对应的是具体的哪个桶,也就是哪个HashEntry链表 HashEntry<K,V> first = entryAt(tab, index); for (HashEntry<K,V> e = first;;) { if (e != null) { K k; if ((k = e.key) == key || (e.hash == hash && key.equals(k))) { oldValue = e.value; if (!onlyIfAbsent) { e.value = value; ++modCount; } break; } e = e.next; } else { if (node != null) node.setNext(first); else node = new HashEntry<K,V>(hash, key, value, first); int c = count + 1; if (c > threshold && tab.length < MAXIMUM_CAPACITY) rehash(node); else setEntryAt(tab, index, node); ++modCount; count = c; oldValue = null; break; } } } finally { //解锁 unlock(); } return oldValue;}[url=][/url]
