标题: Java并发编程-再谈 AbstractQueuedSynchronizer 1 :独占模式(5) [打印本页]
作者: look_w    时间: 2019-1-17 19:40     标题: Java并发编程-再谈 AbstractQueuedSynchronizer 1 :独占模式(5)
实战举例:线程阻塞上述流程只是描述了构建数据结构的过程,并没有描述线程1、线程2阻塞的流程,因此接着继续用实际例子看一下线程1、线程2如何阻塞。贴一下acquireQueued、shouldParkAfterFailedAcquire两个方法源码:
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
final boolean acquireQueued(final Node node, int arg) {
    boolean failed = true;
    try {
        boolean interrupted = false;
        for (;;) {
            final Node p = node.prevecessor();
            if (p == head && tryAcquire(arg)) {
                setHead(node);
                p.next = null; // help GC
                failed = false;
                return interrupted;
            if (shouldParkAfterFailedAcquire(p, node) &&
                parkAndCheckInterrupt())
                interrupted = true;
    } finally {
        if (failed)
            cancelAcquire(node);
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
private static boolean shouldParkAfterFailedAcquire(Node prev, Node node) {
    int ws = prev.waitStatus;
    if (ws == Node.SIGNAL)
         * This node has already set status asking a release
         * to signal it, so it can safely park.
        return true;
    if (ws > 0) {
         * prevecessor was cancelled. Skip over prevecessors and
         * indicate retry.
        do {
            node.prev = prev = prev.prev;
        } while (prev.waitStatus > 0);
        prev.next = node;
    } else {
         * waitStatus must be 0 or PROPAGATE.  Indicate that we
         * need a signal, but don't park yet.  Caller will need to
         * retry to make sure it cannot acquire before parking.
        compareAndSetWaitStatus(prev, ws, Node.SIGNAL);
    return false;
首先是线程1,它的前驱节点是head节点,在它tryAcquire成功的情况下,执行第8行~第11行的代码。做几件事情:
因此,如果线程1执行tryAcquire成功,那么数据结构将变为:
从上述流程可以总结到:只有前驱节点为head的节点会尝试tryAcquire,其余都不会,结合后面的release选继承者的方式,保证了先acquire失败的线程会优先从阻塞状态中解除去重新acquire。这是一种公平的acquire方式,因为它遵循”先到先得”原则,但是我们可以动动手脚让这种公平变为非公平,比如ReentrantLock默认的非公平模式,这个留在后面说。
那如果线程1执行tryAcquire失败,那么要执行shouldParkAfterFailedAcquire方法了,shouldParkAfterFailedAcquire拿线程1的前驱节点也就是head节点的waitStatus做了一个判断,因为waitStatus=0,因此执行第18行~第20行的逻辑,将head的waitStatus设置为SIGNAL即-1,然后方法返回false,数据结构变为:
看到这里就一个变化:head的waitStatus从0变成了-1。既然shouldParkAfterFailedAcquire返回false,acquireQueued的第13行~第14行的判断自然不通过,继续走for(;;)循环,如果tryAcquire失败显然又来到了shouldParkAfterFailedAcquire方法,此时线程1对应的Node的前驱节点head节点的waitStatus已经变为了SIGNAL即-1,因此执行第4行~第8行的代码,直接返回true出去。
shouldParkAfterFailedAcquire返回true,parkAndCheckInterrupt直接调用LockSupport的park方法:
3
4
private final boolean parkAndCheckInterrupt() {
     LockSupport.park(this);
     return Thread.interrupted();
至此线程1阻塞,线程2阻塞的流程与线程1阻塞的流程相同,可以自己分析一下。
另外再提一个问题,不知道大家会不会想:
我认为这是AbstractQueuedSynchronizer开发人员做了类似自旋的操作。因为很多时候获取acquire进行操作的时间很短,阻塞会引起上下文的切换,而很短时间就从阻塞状态解除,这样相对会比较耗费性能。
因此我们看到线程1自构建完毕Node加入数据结构到阻塞,一共尝试了两次tryAcquire,如果其中有一次成功,那么线程1就没有必要被阻塞,提升了性能。
