标题: rpm、yum、编译安装轻松管理centos7程序包(7) [打印本页]
作者: look_w    时间: 2019-2-18 20:17     标题: rpm、yum、编译安装轻松管理centos7程序包(7)
5、查看某包制作时随版本变化的changelog信息;
            rpm-q --changelog PACKAGE_NAME
# rpm -q --changelog zsh
* 四 11月 05 2015 Kamil Dudka <kdudka@redhat.com> - 5.1.1-3
- make loading of module's dependencies work again (#1277996)
* 四 10月 08 2015 Kamil Dudka <kdudka@redhat.com> - 5.1.1-2
- fix crash in ksh mode with -n and $HOME (#1269883)
* 一 9月 14 2015 Kamil Dudka <kdudka@redhat.com> - 5.1.1-1
- Update to latest upstream release: Zsh 5.1.1
* 一 8月 31 2015 Kamil Dudka <kdudka@redhat.com> - 5.1-1
- remove outdated workarounds in %check
* 四 7月 30 2015 Kamil Dudka <kdudka@redhat.com> - 5.0.8-6
- fix handling of command substitution in math context
* 三 7月 22 2015 Kamil Dudka <kdudka@redhat.com> - 5.0.8-5
- prevent infinite recursion in ihungetc() (#1245712)
* 二 7月 07 2015 Kamil Dudka <kdudka@redhat.com> - 5.0.8-4
- backport completion for dnf (#1239337)
* 四 7月 02 2015 Kamil Dudka <kdudka@redhat.com> - 5.0.8-3
- backport completion-related upstream fixes (#1238544)
* 五 6月 19 2015 Fedora Release Engineering <rel-eng@lists.fedoraproject.org> - 5.0.8-2
- Rebuilt for https://fedoraproject.org/wiki/Fedora_23_Mass_Rebuild
* 三 6月 03 2015 Kamil Dudka <kdudka@redhat.com> - 5.0.8-1
- Update to latest upstream release: Zsh 5.0.8
* 五 5月 22 2015 Kamil Dudka <kdudka@redhat.com> - 5.0.7-8
- fix SIGSEGV of the syntax check in ksh emulation mode (#1222867)
* 一 4月 20 2015 Kamil Dudka <kdudka@redhat.com> - 5.0.7-7
- fix SIGSEGV when handling heredocs and keyboard interrupt (#972624)
- queue signals when manipulating global state to avoid deadlock
* 日 1月 25 2015 Kamil Dudka <kdudka@redhat.com> - 5.0.7-6
- use correct allocation function in the new 'cd' code (#1183238)
* 五 1月 23 2015 Kamil Dudka <kdudka@redhat.com> - 5.0.7-5
- suppress a warning about closing an already closed file descriptor (#1184002)
- improve handling of NULL in the 'cd' built-in (#1183238)
* 三 11月 19 2014 Kamil Dudka <kdudka@redhat.com> - 5.0.7-4
- update documentation of POSIX_JOBS in the zshoptions.1 man page (#1162198)
* 二 11月 18 2014 Kamil Dudka <kdudka@redhat.com> - 5.0.7-3
- replace an incorrect comment in /etc/zshenv (#1164313)
* 一 11月 10 2014 Kamil Dudka <kdudka@redhat.com> - 5.0.7-2
- make the wait built-in work for already exited processes (#1162198)
* 三 10月 08 2014 Dominic Hopf <dmaphy@fedoraproject.org> - 5.0.7-1
- Update to latest upstream release: Zsh 5.0.7
* 四 8月 28 2014 Dominic Hopf <dmaphy@fedoraproject.org> - 5.0.6-1
- Update to latest upstream release: Zsh 5.0.6
* 一 8月 18 2014 Fedora Release Engineering <rel-eng@lists.fedoraproject.org> - 5.0.5-8
- Rebuilt for https://fedoraproject.org/wiki/Fedora_21_22_Mass_Rebuild
* 四 7月 17 2014 Dominic Hopf <dmaphy@fedoraproject.org> - 5.0.5-7
- apply upstream patch which fixes CPU load issue (RHBZ#1120424)
* 三 7月 09 2014 Adam Jackson <ajax@redhat.com> 5.0.5-6
- Fix missing 'fi' in %post
* 四 7月 03 2014 Dominic Hopf <dmaphy@fedoraproject.org> - 5.0.5-5
- improve handling of /etc/shells
* 三 7月 02 2014 Dominic Hopf <dmaphy@fedoraproject.org> - 5.0.5-4
- fix FTBFS issue (RHBZ#1106713)
- remove individual _bindir setting; install to /usr/bin/ (RHBZ#1034060)
- require info package instead of /sbin/install-info binary
* 六 6月 07 2014 Fedora Release Engineering <rel-eng@lists.fedoraproject.org> - 5.0.5-2
- Rebuilt for https://fedoraproject.org/wiki/Fedora_21_Mass_Rebuild
* 二 4月 08 2014 Dominic Hopf <dmaphy@fedoraproject.org> - 5.0.5-1
- Update to latest upstream release: Zsh 5.0.5
* 四 1月 16 2014 James Antill <james@fedoraproject.org> - 5.0.2-8
- Remove unneeded build require on tetex.
* 六 10月 26 2013 Dominic Hopf <dmaphy@fedoraproject.org> - 5.0.2-7
- Require hostname package instead of /bin/hostname
* 二 10月 22 2013 Dominic Hopf <dmaphy@fedoraproject.org> - 5.0.2-6
- remove systemd completion, it delivers it's own now (RHBZ#1022039)
* 四 8月 01 2013 Dominic Hopf <dmaphy@fedoraproject.org> - 5.0.2-5
- update systemd completion (adds machinectl command)
* 二 6月 25 2013 Dominic Hopf <dmaphy@fedoraproject.org> - 5.0.2-4
- up-to-date systemd completion (#949003)
- apply patch for building for aarch64 (#926864)
* 一 4月 15 2013 James Antill <james@fedoraproject.org> - 5.0.2-3
- Fix the changelog dates.
- Fix the texi itemx bug.
- Resolves: bug#927863
* 五 2月 15 2013 Fedora Release Engineering <rel-eng@lists.fedoraproject.org> - 5.0.2-2
- Rebuilt for https://fedoraproject.org/wiki/Fedora_19_Mass_Rebuild
* 二 1月 08 2013 Dominic Hopf <dmaphy@fedoraproject.org> - 5.0.2-1
- Update to new upstream version: Zsh 5.0.2
* 三 11月 21 2012 Dominic Hopf <dmaphy@fedoraproject.org> - 5.0.0-1
- Update to new upstream version: Zsh 5.0.0
* 日 7月 22 2012 Fedora Release Engineering <rel-eng@lists.fedoraproject.org> - 4.3.17-2
- Rebuilt for https://fedoraproject.org/wiki/Fedora_18_Mass_Rebuild
* 日 3月 04 2012 Dominic Hopf <dmaphy@fedoraproject.org> - 4.3.17-1
- Update to new upstream version: Zsh 4.3.17
* 六 1月 14 2012 Fedora Release Engineering <rel-eng@lists.fedoraproject.org> - 4.3.15-2
- Rebuilt for https://fedoraproject.org/wiki/Fedora_17_Mass_Rebuild
* 六 12月 24 2011 Dominic Hopf <dmaphy@fedoraproject.org> - 4.3.15-1
- Update to new upstream version: Zsh 4.3.15
* 六 12月 17 2011 Dominic Hopf <dmaphy@fedoraproject.org> - 4.3.14-2
- change the License field to MIT (RHBZ#768548)
* 六 12月 10 2011 Dominic Hopf <dmaphy@fedoraproject.org> - 4.3.14-1
- Update to new upstream version: Zsh 4.3.14
* 六 12月 03 2011 Dominic Hopf <dmaphy@fedoraproject.org> - 4.3.13-1
- Update to new upstream version: Zsh 4.3.13
* 六 8月 13 2011 Dominic Hopf <dmaphy@fedoraproject.org> - 4.3.12-1
- Update to new upstream version: Zsh 4.3.12
* 二 2月 08 2011 Fedora Release Engineering <rel-eng@lists.fedoraproject.org> - 4.3.11-2
- Rebuilt for https://fedoraproject.org/wiki/Fedora_15_Mass_Rebuild
* 四 1月 20 2011 Christopher Ailon <caillon@redhat.com> - 4.3.11-1
- Rebase to upstream version 4.3.11
* 二 12月 07 2010 Toshio Kuratomi <toshio@fedoraproject.org> - 4.3.10-6
- Rebuild for FTBFS https://bugzilla.redhat.com/show_bug.cgi?id=631197
- Remove deprecated PreReq, the packages aren't needed at runtime and they're
  already in Requires(post,preun,etc): lines.
* 一 3月 22 2010 James Antill <james@fedoraproject.org> - 4.3.10-5
- Add pathmunge to our /etc/zshrc, for profile.d compat.
- Resolves: bug#548960
* 五 8月 07 2009 James Antill <james@fedoraproject.org> - 4.3.10-4
- Allow --excludedocs command to work!
- Resolves: bug#515986
* 一 7月 27 2009 Fedora Release Engineering <rel-eng@lists.fedoraproject.org> - 4.3.10-3
- Rebuilt for https://fedoraproject.org/wiki/Fedora_12_Mass_Rebuild
* 一 7月 20 2009 James Antill <james@fedoraproject.org> - 4.3.10-1
- Import new upstream 4.3.10
* 三 6月 10 2009 Karsten Hopp <karsten@redhat.com> 4.3.9-4.1
- skip D02glob test on s390, too
* 一 3月 02 2009 James Antill <james@fedoraproject.org> - 4.3.9-4
- Remove D02glob testcase on ppc/ppc64, and hope noone cares
* 三 2月 25 2009 Fedora Release Engineering <rel-eng@lists.fedoraproject.org> - 4.3.9-2
