Caused by: org.springframework.data.redis.RedisConnectionFailureException: Cannot get Jedis connection; nested exception is redis.clients.jedis.exceptions.JedisConnectionException: Could not get a resource from the pool
at org.springframework.data.redis.connection.jedis.JedisConnectionFactory.fetchJedisConnector(JedisConnectionFactory.java:97)
at org.springframework.data.redis.connection.jedis.JedisConnectionFactory.getConnection(JedisConnectionFactory.java:143)
at org.springframework.data.redis.connection.jedis.JedisConnectionFactory.getConnection(JedisConnectionFactory.java:41)
at org.springframework.data.redis.core.RedisConnectionUtils.doGetConnection(RedisConnectionUtils.java:85)
at org.springframework.data.redis.core.RedisConnectionUtils.getConnection(RedisConnectionUtils.java:55)
at org.springframework.data.redis.core.RedisTemplate.execute(RedisTemplate.java:169)
at org.springframework.data.redis.core.RedisTemplate.execute(RedisTemplate.java:149)
... 76 more
Caused by: redis.clients.jedis.exceptions.JedisConnectionException: Could not get a resource from the pool
at redis.clients.util.Pool.getResource(Pool.java:22)
at org.springframework.data.redis.connection.jedis.JedisConnectionFactory.fetchJedisConnector(JedisConnectionFactory.java:90)
... 83 more
Caused by: java.util.NoSuchElementException: Could not create a validated object, cause: ValidateObject failed
at org.apache.commons.pool.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:871)
at redis.clients.util.Pool.getResource(Pool.java:20)
... 84 more
