* Copyright (c) 2012-2013, Michael Yang 杨福海 (www.yangfuhai.com).
* <p>
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* <p>
* http://www.apache.org/licenses/LICENSE-2.0
* <p>
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
package com.hwc.oklib.util;
* 创建时间:2016/6/27
* 编写者:黄伟才
* 功能描述:ASimpleCache是一个为android制定的轻量级的开源缓存框架
* (替换SharePreference当做配置文件)
public class ACache {
public static final int TIME_HOUR = 60 * 60;
public static final int TIME_DAY = TIME_HOUR * 24;
private static final int MAX_SIZE = 1000 * 1000 * 50; // 50 mb
private static final int MAX_COUNT = Integer.MAX_VALUE; // 不限制存放数据的数量
private static Map<String, ACache> mInstanceMap = new HashMap<String, ACache>();
private ACacheManager mCache;
public static ACache get(Context ctx) {
return get(ctx, "ACache");
public static ACache get(Context ctx, String cacheName) {
File f = new File(ctx.getCacheDir(), cacheName);
return get(f, MAX_SIZE, MAX_COUNT);
public static ACache get(Context ctx, long max_zise, int max_count) {
File f = new File(ctx.getCacheDir(), "ACache");
return get(f, max_zise, max_count);
public static ACache get(File cacheDir, long max_zise, int max_count) {
ACache manager = mInstanceMap.get(cacheDir.getAbsoluteFile() + myPid());
if (manager == null) {
manager = new ACache(cacheDir, max_zise, max_count);
mInstanceMap.put(cacheDir.getAbsolutePath() + myPid(), manager);
return manager;
private ACache(File cacheDir, long max_size, int max_count) {
if (!cacheDir.exists() && !cacheDir.mkdirs()) {
throw new RuntimeException("can't make dirs in "
+ cacheDir.getAbsolutePath());
mCache = new ACacheManager(cacheDir, max_size, max_count);
